  3. How do I get ADEXL to update and fill in missing MonteCarlo...
  • Subscribers 128
  • Views 13529
How do I get ADEXL to update and fill in missing MonteCarlo trials that failed to converge?
billnxp
billnxp over 12 years ago
About 5% of my trials failed to converge.  I don't want to run the whole lot again once I found a fix for convergence, so how do I do it?
I did test the worst failing trial and get it to converge using 'Save Stat to Corner' and testing that.  Ok, now that I have a better convergnce set up in the current test, how do I get that to run with the broken trials in a way that will update the full set ??
It seemed a reasonable assumption, that the History->ManteCarlo.2->Rerun Unfinished/Errors  would infact do just that but with the new test set up.
Sadly NO.  When I look at the re-run input.scs there is no difference in the simulator options from the original.
So,  how do I repair my MC runs that don't converge,  but will with the new test set up?
Thanks....
