  3. delay calculation
  • Subscribers 129
  • Views 15149
delay calculation
arundevnkumar
arundevnkumar over 12 years ago
i want to calculate delay for my circuit.my circuit is designed based on GDI-technique.
In the normal cmos circuit, vinput is nothing but a pulse.
If i give pulse ,i knew how to calculate delay.but in my circuit gate voltage(vinput) is dc.
in Dc there is no rise and fall delay,then how can i calculte the delay
With regards
Arunkumar.N
    I must admit I'm not really familiar with the GDI technique (I did a quick google search to enlighten myself a little). There are a number of papers which talk about simulation - for example http://arxiv.org/abs/1207.2840 . I didn't spend too much time on this, but I can only imagine that for this to be a useful technique, you must be able to have signals that change and are not stuck at DC. Measuring delay with DC signals sounds like an oxymoron to me, and I don't see why you can't varying the inputs and then see how the outputs change in order to measure delay.
    I suggest you do some more research as to how others have tackled this by consulting papers written on this topic.
  • arundevnkumar
    Hi Andrew Beckett,
    Thank you.
