  3. How to edit Bus label both in Copmpser & Virtuoso
  • Subscribers 129
  • Views 3997
RFStuff
RFStuff over 12 years ago
 Dear All,
In compser-schematic ( pressing Key-L for labelling , and using multple line option in the form) and in virtuoso(may be using Turbotool box), one can create a label let's say ( ABC<0:64>) for the BUS and place it at the appropriate locations
But suppose I want to edit the BUS label already placed ( say from ABC<0:64>) to XYZ<0:64>). I don't want to create them again and then take the pain to place again at desired locations.
Is there any way I can achieve this .
Kind Regards,
    Edit->Search->Replace (in IC5141)  or Edit->Replace (in IC615), and then:
    Search For: netName == abc<*>
    Replace With: netname  xyz<{1}>
    Hit Apply to do the Search, and then ReplaceAll to replace the labels. The {1} is referring to the first wildcard in the search pattern.
  • RFStuff
     Dear Andrew,
    Thanks a lot for your reply.
    But in virtuso, I tried the same technique ( mine is IC5141). But in the Search form I was not able to enter the label name itself.
    What is the issue I couldn't figure out.
    Kind regards,
