  3. How to load my configeration files from my working directory...
  • Subscribers 128
  • Views 19110
How to load my configeration files from my working directory not home directory
wgtkan
wgtkan over 12 years ago
How do I load my configuration files (.cdsenv and .cdsinit) from my working directory not the home directory? Because I have multiple design kits and this is creating a bit of confusion. What do I have to do?
Thanks in advance.
  • skillUser
    skillUser over 12 years ago
    By default the tools will look in the current directory for a .cdsinit file, but if one was found earlier in the search path, that one would have been loaded and the search stops (i.e. the first one found is loaded) - if this is the case then that file could include a statement to load a ./.cdsinit if present, something like:
    when(isFile("./.cdsinit")
      printf("Loading .cdsinit from current directory %s\n" getWorkingDir())
      load("./.cdsinit")
    For the .cdsenv file there is an environment variable that controls the loading, you would want a setting that includes the current directory:
    setenv CDS_LOAD_ENV addCWD
    [valid values are False, CWD, addCWD, CWDElseHome and CSF]
    So your choice depends on whether you wish to find and load other .cdsenv files and in which order (e.g. "addCWD" would load the current directory .cdsenv after a ~/.cdsenv file).
    The "CSF" choice is the Cadence Search Facility - look this up in the documentation, it affects the search paths and order of many setup files.
    Hopefully this helps you.
    Best regards,
    Lawrence
  • wgtkan
     Do I write that in .cdsinit file?
  • skillUser
    Which bit?  The [when(isFile...] part is SKILL, so that would go in a .cdsinit file, such as the site .cdsinit file <if any>.  The setenv staement is for setting a Unix environment variable and therefore can go in your terminal or .cshrc (or similar if using a shell other than 'csh').
  • wgtkan
    Normal 0 false false false EN-US X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:8.0pt; mso-para-margin-left:0in; line-height:107%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
    I copied: when(isFile("./.cdsinit")
      load("./.cdsinit")
    Into the .cdsinit file.
    I also set the environment so that .cdsenv get loaded from my current directory. It doesn’t seem to work. I have 2 PDK’s in two different working directories with their respective configuration files (.cdsenv and .cdsinit) but for some reason when I start a new cadence session .cdsenv is loaded from the home (root) directory.
    How do I fix this issue?
    Thank you very much
