  3. How to force VSR using Via Variants
  • Subscribers 129
  • Views 15685
Kristof38
Kristof38 over 12 years ago
Hello community,
 I am trying to route a layout with VSR and I want it to use my customized vias instead of the standard ones which cause too many DRC jog errors.
Despite my overloaded constraints (see snapshot attached), VSR keeps placing its standard vias instead of mine.
 Is there anyone kind enough to have a look at my below routing tcl script?
 Thanks.
 Christophe.
Virtuoso version: virtuoso-6.1.5.500.14 -64
 TCL Routing Script:
# * RDE Sequencer Generated Script *
# *      Initialize Step            *
source /usr/pack/cds-ic-6.1.5.500.14-da/tools/catena/rde/sequencer/scripting.step
::rdeScript::ReleaseSets
setvar db.user_namespace cdba
setvar db.allow_pin_to_pin_space_checking true
setvar db.save_empty_nets true
setvar db.load_lef_props false
setvar db.check_constraints_basics true
setvar db.connect_IO_pin_shapes true
setvar db.paths_as_routes false
setvar db.clearance_based_zoning false
setvar db.make_prboundary_blockage true
setvar db.save_topological_guides_only true
setvar db.zone_unplaced_instances false
setvar db.default_rule_spec_name Christophe_WA_Net
set libName  "cmg_try"
set cellName "comp_bist_eng_DAC_2v_4v"
set viewName layout
virtuoso_setup_default_rulespec -lib $libName -cell $cellName -view $viewName
set result [ read_db -lib $libName -cell $cellName -view $viewName -mode "a" -design_type devicelevel ]
if { $result == "oa:0" } {
    return false
set singleNets [ ::rdeScript::GetSingleNets ]
if { $::rdeScript::excludeSet != "" } {
    set singleNets [ not_sets -set1 $singleNets -set2 $::rdeScript::excludeSet ]
::rdeScript::SetWorkingSet $singleNets
set workingSet [ ::rdeScript::GetWorkingSet ]
set ::rdeScript::lockSet [ create_set ]
set ::rdeScript::lockSet [or_sets -set1 $::rdeScript::lockSet -set2 [find_net  -net_type { power ground }]]
set ::rdeScript::lockSet [or_sets -set1 $::rdeScript::lockSet -set2 [find_net  -net_type { clock }]]
set ::rdeScript::gotLockSet trueTaper
set_route_fix_status -set $::rdeScript::lockSet -status fixed -keep_existing_locked_or_fixed_status true
set_default_constraint_group -group Christophe_WA_Net
set_routespec_taper -taper_route_spec Christophe_WA_Taper
set_route_on_grid -on_grid false
set bottomRoutingLayer M1
set topRoutingLayer M3
set routingLayers [get_layers -material { metal poly } -routing true]
if { [lsearch -exact $routingLayers $bottomRoutingLayer] > [lsearch -exact $routingLayers $topRoutingLayer] } {
  set tempRoutingLayer M1
  set bottomRoutingLayer M3
  set topRoutingLayer $tempRoutingLayer
set limitRoutingLayers [lrange $routingLayers [lsearch -exact $routingLayers $bottomRoutingLayer]\
[lsearch -exact $routingLayers $topRoutingLayer]]
::rdeScript::SetLimitRoutingLayers $limitRoutingLayers
# Special blockage treatment is disabled
set cutClassNames [get_cut_class_names -lib $libName -cell $cellName -view $viewName]
#create_derived_vias -cut_layers existing -replace stdVias -std_via_def true -silent
#foreach cutClass $cutClassNames {
#    create_derived_vias -cut_layers existing -cut_class_names $cutClass -std_via_def true -cut_rows 1 -cut_columns 1 -silent
puts "Running extraction"
extract_net_connectivity -start_level 1 -stop_level 32 -flatten_to_depth 2 -apply_pin_style_to_top_cell -flatten_all_lpps -extract_poly true
update_net_connectivity -set $workingSet
# *      Detail Route Step           *
setvar droute.snap_to_pin_center false
setvar droute.device_pattern 0
setvar droute.complete_all_guides false
setvar droute.punch_effective_shapes true
set drouteCommand "detail_route -dynamic_check_level 3 -check_level 3 -exclude_type { clock power ground }"
set spaceChar " "
set drouteCommand [ concat $drouteCommand $spaceChar [format "-set %s" $workingSet] ]
puts "Running detail route as $drouteCommand"
eval $drouteCommand
# *      Refinement Step           *
set workingSet [::rdeScript::GetWorkingSet ]
set searchAndRepairCmd "search_and_repair -close_opens -exclude_type { clock power ground }"
set spaceChar " "
set searchAndRepairCmd [ concat $searchAndRepairCmd $spaceChar [format "-set %s" $workingSet] ]
puts "Doing search and repair"
eval $searchAndRepairCmd
set routeOptimizeCmd "route_optimize -truncate_at_pins true"
set spaceChar " "
set routeOptimizeCmd [ concat $routeOptimizeCmd $spaceChar [format "-set %s" $workingSet] ]
puts "Doing route optimize"
eval $routeOptimizeCmd
set adjustViasCmd "adjust_vias -offset_via true -minarea -edgelength -numcuts"
set spaceChar " "
set adjustViasCmd [ concat $adjustViasCmd $spaceChar [format "-set %s" $workingSet] ]
puts "Adjusting vias"
eval $adjustViasCmd
set spaceChar " "
set fixErrorsCmd [concat fix_errors -error_types \{ minarea minedge minenclosed minwidth numcut \}   [format "-set %s" $workingSet] ]
puts "Fixing errors"
eval $fixErrorsCmd
set routeOptimizeCmd "route_optimize -maximize_cuts useMaxRule -max_iterations 0 -V false"
set spaceChar " "
puts "Doing final route optimize"
puts "checkpointing the design after refinement"
checkpoint
set ::rdeScript::didSaveOrCheckpoint true
# *      Finalize         *
::rdeScript::UnsetLimitRoutingLayers
puts "checkpointing the design after finalize"
checkpoint
::rdeScript::CheckpointAtEndOfRunIfNeeded
close_db -no_prompt
constraints snapshot:
  • ColinSutlieff
    ColinSutlieff over 12 years ago
    Hi Christophe,
    Before I answer the via variant question I would like to say that this is not normally necessary.
    VSR can fix any jog errors if the DRC information is in the tech file.
    You did not mention how you found the DRC errors. If you used an external checker, it is possible that the rules are not part of the Cadence tech lib. VSR uses the rules in the techlib.
    An easy way to find out is to simply use the DRD batch checker.
    Click verify->design and click the check box "process rules"
    If the batch checker found the DRC errors then there must be a problem with the router sequencer setup.
    Make sure that the option "Minimum Edge Length" is checked in the Refinement step (click the edit button in the sequencer.
    If the checker found no errors then it is a problem with your PDK. The design rules are not sufficiently defined. Either contact your PDK provider or add the missing rules to your Constraint Group.
    Back to your original question:
    I just tested this out with the latest release ( IC6.1.5 ISR 16) and everything worked.
    Perhaps you can try to get access to the latest release.
    Also, your screenshot shows the rules for the Wire Assistant.
    It looks like you created a Constraint Group from the Wire Assistant and then used this C.G as input to the router.
    I would double-check by opening the Process-rule Editor (from the Constraint Manager) and making sure that the via variants are listed in the valid vias section
    So I would try to find out the cause of the DRC errors because VSR should be able to handle this.
    Hope this helps
    Colin
  • Kristof38
    Colin,
    Thanks for your reply. I will try out what you advised.
    Christophe.
