  3. lvsIgnore of voltage source vdc
  • Subscribers 129
  • Views 16193
navi2582
navi2582 over 12 years ago
I have a legacy voltage source "vdc" in IC614 env, modified long time ago (set lvsIgnore to FALSE) and still works fine (gets netlisted during CDL). But, followed the same procedure (copied "vdc" from analogLib to my local directory, modified the lvsIgnore to FALSE in the symbol view) in IC615 env andit doesn't work (doesn't netlist in the CDL).
Am I overlooking something?
I have verified the cdfDump for the two but didn't see any difference.
Any thoughts?
    You'll also need to open the auCdl view of vdc and remove the lvsIgnore and nlAction properties. Looking at my IC614 build, it was the same there too, as far as I can see.
    Certainly these properties on the stop view will be used to determine whether the component should be ignored.
