  3. Using threads (cores) greater than 64 in APS
  • Subscribers 129
  • Views 14443
RFStuff
RFStuff over 12 years ago
 Dear All,
Is it possible to use more than 64 threads in APS ?
 ( When I run a big PEXed circuit with 64 Cores ( manullay setting) SPECTRE gives warning as:-
  WARNING (SPECTRE-407): Total number of threads (I251.N_TIA_Q_IN_PLUS_XI1/XI0/XI18/MC4_g)  exceeds 64 in disributed APS )
Why this warning is cropping up ?
Kind Regards,
  • Ashish Patni
    Ashish Patni over 12 years ago
    Hi RF Stuff,
    APS for now supports upto 64 cores. However, which MMSIM version are you using? You can find this either from the log file or using -
    spectre -W
    from the unix command line.
    The support for 64 cores has been started from MMSIM11.1.
  • RFStuff
     My version is sub-version  12.1.0.347.isr3
    Kind Regards,
  • Ashish Patni
    Hi RF Stuff,
    So, in your version (which is almost latest) as I mentioned in my previous reply, APS supports upto 64 cores.
    With Regards,
    Ashish
    Do note that this number of cores will only be worthwhile if the circuit is massive (multi-millions of components). Also, you're only likely to see scaling in the transient analysis, and I know you've been using APS with the RF analyses - I doubt very much whether you'd see scalable utilization with 64 cores (I suspect memory would be the limiting factor on a large enough design).
