  3. find and replace multiple net expressions on a schemati...
  • Subscribers 129
  • Views 16247
find and replace multiple net expressions on a schematic
rsankara
rsankara over 12 years ago
Hi there,
I am trying to perform a "Find & Replace" of multiple netexpressions in Virtuoso Schematic
I invoked Edit->Replace and in the drop down select box chose netexpr and in the text box typed my expression as
[@nwell:%:vnwell]
Strangely virtuoso schematic returns withwarning #1145, claiming no such objects were found. I can clearly see the object on screen.
(I also tried the simpler option of replacing the label, which does a naive replacement of my net expression's label and abandons the expression part of it, thereby reducing it to a static label. This is not what I want.)
Any help is greatly appreciated
Raj
    Raj,
    Assuming that you meant to have the default value as vnwell! rather than vnwell (the default has to be a global), then it would be:
    \[@nwell:%:vnwell!]
    The initial backslash is to escape the open square bracket which is used to character ranges in the shell-like pattern syntax.
    Or you could just use:
    *nwell*
    or *@nwell:* if you want to make it a bit more specific.
