  3. Netlisting Problem in ADE XL
  • Subscribers 129
  • Views 14948
dannyo
dannyo over 12 years ago
I'm using IC6.1.5.500.14
ADE L works fine for me however when I try to run ADE XL         the netlister adds   a    .definitionFile    containing an incorect model file. As a result of this the netlist has an error an the simulation fails.
Where should i look in the netlister files to find this .definitionFile and overwrite it. Or where can i find the script that compiles the netlist.
Thanks for your help
Danny
    Danny,
    Presumably this is set in the Setup->Simulation Files in the test editor. Maybe it is being defaulted by the .cdsenv :
     spectre.envOpts definitionFiles string  "/path/to/whatever"
  • dannyo
    Dear Andrew,
    Thanks for the reply.
    I can't find any definitionFiles in my .csdenv or .cdsinit
    Could the definitionFile be set by a different file other than .cdsenv ?
    The models file isn't set in Setup/Simulations File, I define a different model file there.
    ADE L works fine for me, ADE XL has this problem with the extra model file being entered into the netlist,
    Is there any way to get ADE XL to use a fixed netlist location and not create new directories for each Run?
    Danny
    Maybe it's in a libInit.il for one of your libraries? Probably the best thing is to contact customer support so that we can look into this.
    Kind Regards,
