  3. Problems when evaluating waveforms from multiple stb analyses...
  • Subscribers 129
  • Views 14462
Problems when evaluating waveforms from multiple stb analyses during transient analysis
Rune
Rune over 12 years ago
I face some problems in adexl with transient and stb analysis at two times points using spectre/mmsim 111 isr22 and ic615.16.2.
I run a transient simulation with ac times(where stb analysis is run): t_stb1 and t_stb2.
I find the loopgain at the two time points with these expressions in adexl:
ymax(dB20(famValue(getData("loopGain" ?result "stb") VAR("t_stb1"))))
ymax(dB20(famValue(getData("loopGain" ?result "stb") VAR("t_stb2"))))
This works for one adexl testbench but not for two others. In latter case, the loop gain for the last time point is evaluated in both cases. Looking at the loopgain waveforms, I see that the waveforms have a "sweep parameter" t_stb2 (which explains why this occurs).
Is there another way to have this correct regardless of what kind of parameters that are for some reason included in the waveform?
  • Rune
    A follow up to this problem.
    This seems to occur with many types of analyses. However, one workaround is to find the sweep parameter name(which, in my case, seems to be an arbitrary variable from the global variables list), and then get the corresponding value. Like this:
    ymax(dB20(mag(famValue(value(v("/INT_AC_LP_DIFF" ?result "ac") famGetSweepName(v("/INT_AC_LP_DIFF" ?result "ac")) famGetSweepValues(v("/INT_AC_LP_DIFF" ?result "ac")))  VAR("t_ac1")))))
    Rune,
    For me, if I use:
    ymax(value(db(mag(getData("loopGain" ?result "stb"))) 'time VAR("tstb1")))
    Then it always works (similarly if I use tstb2 for my second time point. I'm using IC615 ISR16 (6.1.5.500.16.2). However, I do see issues if I just try to have an output:
    then that fails to plot. If I explicitly put the time in there rather than the VAR expression, it works - and I see the additional sweep in the results. Something is definitely wrong here, so I'll file a CCR. I've seen a few similar issues recently.
