  3. single point AC analysis
  • Subscribers 129
  • Views 13622
Steve Mikes
Steve Mikes over 12 years ago
Is there a way to just run a single point AC analysis from the ADE GUI? I can hand-edit the netlist to remove the sweep parameters in the analysis statement and just include a single value (e.g. values=[1G]). But then I have to do this every time I make a change to the netlist.
    No. It ought to be possible (you can for pac for example) - so please create a Case with customer support asking for this enhancement. Seems a very reasonable request to me.
    As a workaround, create a file, analyses.scs, with the analysis statement in:
    ac ac start=1G
    And then reference this file via Setup->Model Libraries in the ADE form. And don't set up the ac analysis from the UI.
