  3. Calculator - Special Functions (xmin & xmax)
  • Subscribers 129
  • Views 4931
DineshBabu
DineshBabu over 12 years ago
 I am exploring the special functions in IC 6.1.
I created a simple inverter and used xmin and xmax of the output signal.
When I use xmin and xmax of the output signal with Nth Minimizer value equal to 1, I get the value corresponding to it.
Whereas, when I have the value of Nth Minimizer equal to 2 or more than 2,  I don't get the expected result.
The following is the error message when the value of Nth minimizer is  =>2.
expression evaluation failed: Expression evaluates to nil
expression evaluation failed: xmin(VT("/out") 2 )
How do I get around with this issue?
Dinesh
    Dinesh,
    Note that xmin and xmax do not return the x-value for a local minimum, but the x-value of the global minimum. The second argument is for when that global minimum (or maximum) appears at more than one x location.
    If you pass 0 as the second argument, you'll get a list of the x values - I suspect there's only one point at which the global minimum/maximum occurs.
