  3. Problem in running tests with different stimulus together...
  • Subscribers 129
  • Views 14825
Problem in running tests with different stimulus together in ADE XL
Parameswaran
Parameswaran over 12 years ago
I am simulating an opamp in ADE XL. I am using differential stimulus to get differential gain in one test & common mode input stimulus for common mode gain in another test. The inputs are provided through user defined stimulus files.When I run these tests together in ADE XL I get an erroneous output. But when I run them separately I get the expected output.Can anyone help me overcome this?
I would prefer running both differential and common mode gain calculation in a single test but I don't know how to handle multiple stimulus files in a single test.Please help.
Thanks in advance,
Parameswaran
    Parameswaran,
    Without knowing what goes wrong, it's hard to advise. I can't see any good reason why you should not be able to have two tests with different stimulus files.
    Having two different stimulus files in the same test doesn't make much sense because you've only got one circuit in each test. If the topology is the same and the parameters are different, you could do that, but not different topologies in the same test.
  • Parameswaran
    Thanks for the reply.
    Both tests use the same schematic.One uses a coomon mode input stimulus and the other differential.When i set them up and run them together in ADE XL,(with auto-plot after simulation checked) ,the common mode simulation(which comes first in the output setup) is plotted correctly but the differential gain output  is stuck at 6.25 kdB.However when i replot the same results from the results window, using the graph icon in "Nominal" column, the plot for diff gain comes as expected (60dB gain). Why is this happening?
    Also, how do I probe the same inputs with two different stimuli in a single test?
    Thanks in advance,
    Parameswaran
    No idea. We'd have to see the data (so suggest you contact customer support).
    And I already said that you can't have two different stimuli in a single test.
