  3. properties unresolved during OSSHNL-366
  • Subscribers 129
  • Views 14287
KMan11
KMan11 over 12 years ago
 I'm battling AMS netlisting issues in IC6.1.5.
I'm trying to use an OSS netlister to netlist and run an database.  I had it working, yet when I created another config view with the same 'view' of a block of IP, I get the following error
ERROR (OSSHNL-366): instance * in cellview '<lib>/<cellname>/<functional' is bound to placed master '<lib>/buf/symbol'
However, OSS has determined that it is not a valid placed master. Ensure the cds.lib has entries for all reference libraries and netlist again.
 I looked at the properties for that IP's functional view and found the following
access   dr-xr-xr-x [r]
files   netlist.oa
   verilog.v
   pc.db
   data.dm
   master.tag
managed by  N/A (data not currently managed)
Properties
dependency  hier >
> children  ILList (("analogLib" "nmos" "symbol") ("<library>" "buf" "symbol"))
cc
I don't have that library, but I don't understand why that library is attached in such a way.
 Can I not override the property at the cell level in my schematic by adding a user property?  If I could add a property which overrides this ILList so it only references say the analogLib nmos, then I'd have thought this would get around the netlist problem.  Can netlist with schematic view (which doesn't have this property), but that defeats the purpose of this view
 K
