  3. Spectre simulation not running at C-extraction level
  • Replies 13
  • Subscribers 133
  • Views 20902
Debasish
Debasish over 12 years ago
I am getting errors during spectre simulation at C-extracted level. The circuit is getting simulated at schematic level. C-extraction is done using Assura41. The spectre version,OS and error message are listed below. I got this error message by running the simulation from terminal window using./runsimulation. The log file is also pasted below.
 IC5 Sub version: sub-version 5.10.41.500.6.151 (32-bit addresses)
Debian Linux ti15 2.6.32-5-amd64 #1 SMP Sun May 6 04:00:17 UTC 2012 x86_64 GNU/Linux
 /cad/tools/cadencetools/mmsim_7_2/tools/bin/spectre: line 267:  1933 Killed        ${APPBINPATH}/${PROGRAM} "$@" 0<&3
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 7.2.0.373.isr13 64bit -- 25 Sep 2010
Copyright (C) 1989-2010 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
Protected by U.S. Patents:
        5,610,847; 5,790,436; 5,812,431; 5,859,785; 5,949,992; 5,987,238;
        6,088,523; 6,101,323; 6,151,698; 6,181,754; 6,260,176; 6,278,964;
        6,349,272; 6,374,390; 6,493,849; 6,504,885; 6,618,837; 6,636,839;
        6,778,025; 6,832,358; 6,851,097; 6,928,626; 7,024,652; 7,035,782;
        7,085,700; 7,143,021; 7,493,240; 7,571,401.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
User: ee11s004   Host: ti15   HostID: 70A7333   PID: 1933
Memory  available: 14.3608 GB  physical: 16.7498 GB
CPU Type: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
          Processor PhysicalID CoreID Frequency
              0         0        0     1600.0
              1         0        1     1600.0
              2         0        2     1600.0
              3         0        3     1600.0
              4         0        0     1600.0
              5         0        1     1600.0
              6         0        2     1600.0
              7         0        3     1600.0
Simulating `input.scs' on ti15 at 11:00:31 AM, Wed Jun 12, 2013 (process id: 1933).
Command line:
        /cad/tools/cadencetools/mmsim_7_2/tools.lnx86/spectre/bin/64bit/spectre  \
        -env artist5.1.0 +escchars +log ../psf/spectre.out -format sst2  \
        -raw ../psf +lqtimeout 900 -maxw 5 -maxn 5 +aps input.scs  \
        +error +warn
Loading /cad/tools/cadencetools/mmsim_7_2/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
Loading /cad/tools/cadencetools/mmsim_7_2/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
Loading /cad/tools/cadencetools/mmsim_7_2/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
Loading /cad/tools/cadencetools/mmsim_7_2/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
Auto-loading AHDL component.
Finished loading AHDL component in 0 s (elapsed).
Installed AHDL simulation interface.
Time for NDB Parsing: CPU = 5.94037 s, elapsed = 10.2763 s.
Time accumulated: CPU = 5.94037 s, elapsed = 10.2763 s.
Peak resident memory used = 423 Mbytes.
Existing shared object for module res_va is up to date.
Installed compiled interface for res_va.
Existing shared object for module db_bin2dec is up to date.
Installed compiled interface for db_bin2dec.
Notice from spectre during circuit read-in.
    "input.scs" 1116: Remove instances `I1|I2|I2|I1|I1|I7409|avD59_1' because its terminals connected together.
    "input.scs" 1118: Remove instances `I1|I2|I2|I1|I1|I7410|avD59_1' because its terminals connected together.
    "input.scs" 1120: Remove instances `I1|I2|I2|I1|I1|I7411|avD59_1' because its terminals connected together.
    "input.scs" 1122: Remove instances `I1|I2|I2|I1|I1|I7412|avD59_1' because its terminals connected together.
    "input.scs" 1124: Remove instances `I1|I2|I2|I1|I1|I8427|avD59_1' because its terminals connected together.
        Further occurrences of this notice will be suppressed.
    Debasish,
    You're probably running with controlMode set to "batch" then - which is fine. What happens if you run ./runSimulation?
    As for the memory problem - since you're running in IC5141, you can't run in 64 bit mode, but my guess is that the issue is the machine resources, not that icfb needs to be in 64 bit mode - presumably you'll need to reduce the amount of thing running on the machine to reduce the overall memory use on the machine.
  • Debasish
    I tried ./runSimulation. I got the same log file as before when the simulation was fired from ADE window. I have attached the spectre.out file also. In the terminal window, the below message came up.
     /cad/tools/cadencetools/MMSIM121/tools.lnx86/bin/spectre[532]: wait: 9042: Killed
    Regards
    Debasish
    • db_top_log_file.txt
    OK, looks as if spectre is crashing during parsing/elaboration of the netlist. After trying the latest hotfix of MMSIM12.1 (assuming that doesn't fix it - currently you're using the base version), you'll need to contact customer support with a testcase showing the issue.
