  3. Fatal Application Error in ASSURA av_extracted
  • Subscribers 130
  • Views 14611
Bayes
Bayes over 12 years ago
I am using 6.1.5 environment and I'm running ASSURA to perform DRC and LVS and it is all right.
Unfortunatelly, then, when I try to run Assura Parasitic Extraction, to generate an extracted view (av_extracted), I have a serious problem since I have the crash of CADENCE and I don't understand where is the problem.
In attachment there are the window that appears when there is the system crash and the related generated log files.
What's happening? What can I do to solve this error/problem?
Thanks a lot in advance for your help,
Andrea.
CrashReport.zip
  • Quek
    Quek over 12 years ago
    Hi Andrea
    It looks like you were running rcx 41 on IC615-500.6 when Virtuoso crashed. This seems to be the same form resize bug which has already been fixed in IC615-500-14. I think you should not see the crash if you use any version higher than IC615-500-14 (e.g. IC616).
    Usually the first few lines of the crash stack is the most important as it helps in identifying the crash signature.
    \o cmd  is /ic_tools/cds/ASSURA.4.1.OA.615/tools/assura/bin/assura /home/cadence/ASSURA_LVS/r_to_t3_core/rcx.r_to_t3_core.rsf -cdslib /home/cadence/cds.lib
    \o Starting the ipc:10 Run: IPC Id 5708: pid "Assura RCX".
    \e *Error* The Assura RCX run "r_to_t3_core" failed!
    \e     The log File is at: /home/cadence/ASSURA_LVS/r_to_t3_core/rcx.r_to_t3_core.log
    \o INFO (DB-170018): (dbPanic) dumping stack
    \o virtuoso:dbPanic+216()
    \o libvirtuos_sh.so:voDoAbortFuncs+37()
    \o libvirtuos_sh.so:voSigAbort+181()
    \o :__kernel_sigreturn+0()
    \o virtuoso:_ZN7HiQForm6resizeEii+89()
    \o virtuoso:_ZN7HiQForm10setExtentsEb+1011()
    \o virtuoso:_Z18hiiInstantiateFormRK13FormStructPtrPN2hi14FieldContainerE+1387()
    \o virtuoso:hifDisplayForm+688()
    \o libil_sh.so:iliVcodeEval2+10526()
    \o libil_sh.so:ilxSkillEval2+220()
    Best regards
    Quek
  • Bayes
    Hi Quek,
    thank you very much!
    I let you know if with the new version, the system will work.
    Best regards
    Andrea.
