  3. spectremdl issue : syntax error before or at: trans invalid...
  • Subscribers 129
  • Views 15049
spectremdl issue : syntax error before or at: trans invalid argument to run statement
samung
samung over 12 years ago
Hello !
I am a new user of spectremdl and I make a basic trial, just to check that it works. I want to print a value in a result file.
I don't know why, I have the below log file issues, and especially :  syntax error before or at: trans invalid argument to run statement
I launch (through a job queue) : spectremdl -batch input.mdl -design input.scs -measure results_file
log file :
Simulating `input.scs' on clust at 30:52:56 AM, Tue Jun 68, 2033 (process
Error found by spectre.
    ERROR: line 11, column 5: syntax error before or at: trans
    ERROR: line 11, column 10: syntax error before or at: <eof>
            unrecognised statement
    ERROR (MDL-6): Failed to parse MDL control file, `input.mdl'.
input.mdl :
alias measurement trans {
input real test_var = 13
run tran_simu
export test_var
run trans
input.scs extract :
simulator lang=spectre
global 0
include "xxx/corners_FF.scs"
parameters nmos_tran_model=nsvtlp pmos_tran_model=psvtlp wpen=xxx  wneqi=xxx ... Rright=10 ... lneqi=xxx  lndiff=xxx ...
subckt inv A1 YN vdd vnw vpw vss
parameters wp=xxx lp=xxx pfolds=1 wn=xxx ln=xxx nfolds=1
M5 (YN A1 vdd vnw) psvtlp w=wp*10e5 l=lp*10e5 nfing=pfolds mult=1  srcefirst=1 mismatch=1 lpe=0 numcos=1 numcod=1 ngcon=1
M2 (YN A1 vss vpw) nsvtlp w=wn*10e5 l=ln*10e5 nfing=nfolds mult=1  srcefirst=1 mismatch=1 lpe=0 numcos=1 numcod=1 ngcon=1
ends inv
// View name: schematic
subckt ncx ncx
ends ncx
// End of subcircuit definition.
Rleft (vli saout_b) resistor r=Rleft
M2 (saout saeqi saout_b vpw) nsvtlp w=xxx l=xxx nfing=1 mult=1  srcefirst=1 mismatch=1 lpe=0 numcos=1 numcod=1 ngcon=1
M1 (saout_b saout vss vpw) nsvtlp w=xxx l=xxx nfing=1 mult=1  srcefirst=1 mismatch=1 lpe=0 numcos=1 numcod=1 ngcon=1
M0 (saout net07 vss vpw) nsvtlp w=xxx l=xxx nfing=1 mult=1  srcefirst=1 mismatch=1 lpe=0 numcos=1 numcod=1 ngcon=1
M4 (vli signal1 vdd vnw) psvtlp w=xxx l=xxx nfing=1 mult=1 srcefirst=1  mismatch=1 lpe=0 numcos=1 numcod=1 ngcon=1
include ".../_graphical_stimuli.scs"
ic saout=xxx saout_b=0
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=70  tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5  digits=5 cols=80 pivrel=1e-3 sensfile="../psf/sens.output"  checklimitdest=psf
tran_simu tran stop=10u write="spectre.ic" writefinal="spectre.fc"  annotate=status maxiters=5
subckts info what=subckts  where=rawfile
save signal1
saveOptions options save=allpub subcktprobelvl=2
Thanks a lot for your help !!
P.
  • samung
    Ok, actually, the issue was that the first line of the .mdl file must not be straigth the "alias measurement" line. Indeed, the following .mdl file returns a sucessfull result : .mdl file : /* test */ alias measurement run_tran_simu { run tran export real test_var = 13 } run run_tran_simu P.
