  3. Dynamic abstract generation in layout XL
  • Subscribers 130
  • Views 14519
Sandeep4386
Sandeep4386 over 12 years ago
I was going through abstract generator user guide, I din't quite understand what's the main benifits of using dynamic abstract generation? I get it that it can create abstracts for the pcell on the fly, but can't we achieve same thing using regular abstract generator?
Could anyone brief me about motivation behind using daynamic abstract generator?
Sandeep
  • theopaone
    theopaone over 12 years ago
     There are two types of cells in Virtuoso, static or fixed cells and programmable cells (pcells, vias, etc.) The static cells are the same at each instance and you can create a single abstract which represents the data in that cell. This can be done in batch and saved on disk as a view.
    The parameterized cell does not have a usable disk representation, only the superMaster. All the masters of a pcell are calculated bsed on the parameter values assigned to the instance of the cell. Each unique set of parameter values creates a new pcell master in Virtual Memory (VM). Since these masters only exist in VM (expresso cells not considered persistent on disk storage for a master), the abstract can only be generated dynamically, representing the data from the masters.
    Ted
  • Sandeep4386
    Thanks Ted, that was helpful,
    Do you have any idea if dynamic abstraction can be done on python based pcells?
    -Sandeep
  • theopaone
     Hi Sandeep
    I don't know. You will have to try that yourself.
    Ted
