  3. help with Abstract generator
  • Subscribers 129
  • Views 13891
sardar1
sardar1 over 12 years ago
 Dear friends
    First of all I take this oppertunity to say hi , I hope to have a great, honorable and informative virtual  kinship with all of you.
The problem I am facing is with the Abstract generator, I have a few verilog modules that are nested and I have created their GDS through encounter. I imported that GDS in abstract generator and want to create a one cell  lef. Now that I run the pin step the tool constantly gives me error ABS- 520 "cannot create net named "xyz" from the database".
If I give a single module it creates its lef but If I give the same module as an instiation it gives me this error. Any form of help will be highly appreciated.
Thanks in advance
sardar
    Hi Sardar,
    I would suggest that you contact customer support - it would probably help enormously to be able to see your data to diagnose your problem.
    Kind Regards,
