  3. How do I implement this offset logic in ocean script?
  • Subscribers 129
  • Views 13987
chaosatom
chaosatom over 12 years ago
I have a ramp in my input of comparator and I am getting the offset by implementing this logic in ocean script. If clock= 1 and output= 1 in an transient response, then get the x-value for the first time that it happens. From that x-value, get the y-value of input. How would I accomplish this?
Do I need to loop through each time step and see where it occurs? Or is there an easier implementation for it? I am new to ocean script.
  • chaosatom
    I have this code that works in ocean: (Basically I sweep time and store the Vin value on to a text file)
    for(tt 1 1200
      time = (tt*.0005)-.0005
              if( (value(VT("/Vout"), time)<=.8 && value(VT("/clk"), time)>=1) && (value(VT("/Vout"), time)>=.1)
                     then fprintf(of "Vin = %1.3f \n" value(VT("/Vn"),time))
    I want to add this ocean script to a calculator and display the Vin value on the output of ADE window (then run Monte carlo). Can anybody give me a step by step guide on how to proceed?
    Vipul
    Vipul,
    Probably I'd do this using the code in this post (also in this post). You could also define:
    procedure(abWithinRange(wave min max)
      abApplyToWave(
        lambda((val)
          cond(
            (val<max 1)
            (val>min 1)
            (t 0)
    In conjunction with abPositive in the earlier post, you'd do:
    value(VT("/Vin") cross(abPositive(VT("/clk")-1)*abWithinRange(VT("/Vout") 0.1 0.8) 0.5 "rising"))
    Something like that.
    I'll link your earlier question to this, because I think it answers both. Your above approach won't really work because it doesn't output a single value - but you could of course alter the logic to return a single value and encapsulate it in a function definition.
    Kind Regards,
