  3. Easy way to exchange schematics from a library?
  • Subscribers 130
  • Views 15727
Lynks
Lynks over 12 years ago
I was wondering if there's a simple way to exchange schematic designs (and related dependencies). For example, we have a large library of cells with schematic, symbol and layout views. And for a given cell, I'd like to package together only the relevant schematic views (and dependencies) in a single file that my colleague can import and work with.
 Currently, I would have to zip up the entire library directory and send the zip but the library has become quite large that I now have to eliminate unnecessary files that my colleague does not need.
 Any simple way to do this? Any help is greatly appreciated.
  • Marc Heise
    Marc Heise over 12 years ago
     Hi Lynks,
    please check out the "Copy Wizard" in the Edit menu of the Library Manager. You will find there what you are looking for. Please make use of the "Help" buttons there if something is not selfexplaining.
    Marc
  • Lynks
    Hi Marc, thank you so much for your help. This is almost nearly my ideal solution. If only I didn't have to specify a destination library but rather some sort of single file format that I can exchange with colleagues. But this is sufficient as I can zip up the truncated destination library for exchange.
    Thanks again for your help.
