  3. Obtaining zero temperature coefficient
  • Replies 7
  • Subscribers 129
  • Views 17504
wgtkan
wgtkan over 12 years ago
I am trying to simulate to obtain a zero temperature coefficient of an NMOS. I swept gate-source voltages and probed the drain current and did step temperature in parametric analysis and for some reason, I do not get the temperature displayed at different values. I am attaching the image of what I am trying to do.
 Thank you in advance.
    You didn't show what your problem is - so not sure what you've done wrong. I just ran a simple netlist-only based example:
    model nch bsim4 type=n
    M1 (D G 0 0) nch w=1u l=0.25u
    VDS (D 0) vsource dc=0.7
    VGS (G 0) vsource dc=0.5
    save M1:d
    tempSweep sweep param=temp start=25 stop=125 step=50 {
        dc dc dev=VGS param=dc start=0.2 stop=0.45 step=0.002
    I got the curves below.
  • Marc Heise
    Marc Heise over 12 years ago
    I think he wants to have the temperature at the x-axis and find the "flat" wave.
    Just do a temp sweep in the DC setup and run the gate voltage as parameter.  Than you could try to   ymax(IS)-ymin(IS)    or find any other math to judge your results.
    Marc,
    Maybe, but the graph I plotted is exactly how the pictures he uploaded look - so if that's not what he wanted, it would have been better to explain precisely what he wanted (that said, I don't understand what the issue is with doing this - it was straightforward).
  • Marc Heise
     He is not doing anything wrong , he just needs a calculator expression  to find the crossing of the waves. Or like I proposed, simulate it the other way around and find the flat wave.
  • wgtkan
     Hello Andrew and Marc:
    What I had originally is exactly as Andrew put it. I swept my VGS from 0.1 – 1.2V and did parametric sweep for temperature – 0:25:100. But I do not get the zero crossing point. I get the same curves at different temperatures. I am using psp model in IBM8HP 130nm process and I have selected tt for the section. Do you think that I have to do it for different corner?
    I re did it this time by sweeping my Gate-source voltage from 200mv to 450mv at the step size of 2mv and a parametric sweep of temperature from 0 to 100 at a step size of 25 and I get the following plot. It doesn’t make no sense.
  • wgtkan
     I am also including my net list:
    // Generated for: spectre
    // Generated on: Aug  6 07:51:55 2013
    // Design library name: Baker
    // Design cell name: Ex23pa
    simulator lang=spectre
    global 0
    parameters Ln=250n Wn=1000n _gpar0=0
    include "design.scs"
    include "allModels.scs" section=tt
    // Library name: Baker
    // Cell name: Ex23pa
    // View name: schematic
    T0 (net1 net02 0 0) nfet l=Ln w=Wn nf=1 m=1 par=(1) ngcon=1 \
            ad=(Wn*5.5e-07) as=(Wn*5.5e-07) pd=(2*Wn+2*5.5e-07) \
            ps=(2*Wn+2*5.5e-07) nrd=1.8e-07/Wn nrs=1.8e-07/Wn rf_rsub=1 \
            plnest=-1 plorient=-1 pld200=-1 pwd100=-1 lstis=1 lnws=0 panw1=0p \
            panw2=0p panw3=0p panw4=0p panw5=0p panw6=0p panw7=0p panw8=0p \
            panw9=0p panw10=0p sa=5.5e-07 sb=5.5e-07 sd=0u dtemp=0.0 gns=0
    VGS (net02 0) vsource dc=500.0m type=dc
    VDS (net1 0) vsource dc=700.0m type=dc
    simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
        tnom=25 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
        checklimitdest=psf
    dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
    dcOpInfo info what=oppoint where=rawfile
    dc dc dev=VGS param=dc start=0.2 stop=0.45 step=2m oppoint=rawfile \
    subckts info what=subckts  where=rawfile
    save T0:d
    Unfortunately I don't have access to the models - so probably the best thing is to report this to customer support. and then we can go throught the formal process of requesting the models from IBM.
    Kind Regards,
