  3. spectre nested sweep in MC run fails to "export" expres...
  • Replies 11
  • Views 9056
spectre nested sweep in MC run fails to "export" expression
kxlux
kxlux over 12 years ago
 Here is my netlist(analysis part of.., produced from ADEXL):
________________________________________________________________________________________
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=70 \
    tnom=27 homotopy=dptran scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 \
    sensfile="../psf/sens.output" checklimitdest=psf
mc1 montecarlo numruns=1 seed=12345 variations=all sampling=standard \
    donominal=no scalarfile="../monteCarlo/mcdata" \
    paramfile="../monteCarlo/mcparam" saveprocessparams=yes \
    processparamfile="../monteCarlo/processParam" \
    processscalarfile="../monteCarlo/processData" savemismatchparams=yes \
    mismatchparamfile="../monteCarlo/mismatchparam" \
    mismatchscalarfile="../monteCarlo/mismatchdata" \
    dumpdependency=mismatch \
    dependencymapfile="../monteCarlo/mismatchdependency" \
    savefamilyplots=yes savedatainseparatedir=yes firstrun=15 {
swp0 sweep param=EQ values=[0 1 2 3] {
dcOp0 dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
dcOpInfo0 info what=oppoint where=rawfile
ac0 ac start=10K stop=10G lin=1 annotate=status
modelParameter0 info what=models where=rawfile
element0 info what=inst where=rawfile
outputParameter0 info what=output where=rawfile
designParamVals0 info what=parameters where=rawfile
primitives0 info what=primitives where=rawfile
export real Gain100k0=oceanEval("value((dB20((VF(\"VOP\") - VF(\"VON\"))) - dB20((VF(\"CHINP\") - VF(\"CHINN\")))) 1e+4)")
export real Gain13G0=oceanEval("value((dB20((VF(\"VOP\") - VF(\"VON\"))) - dB20((VF(\"CHINP\") - VF(\"CHINN\")))) 1.0e+10)")
mcOptions options genmcdep=yes
save V10CUR:p V33CUR:p VIP_IN VIN_IN I1.I1.CTLEOUT2 I1.I1.CTLEOUT2B VOP \
    VON CHINP CHINN I1.I1.I0.CTLEOUT1 I1.I1.I0.CTLEOUT1B I2.I15.M7:1 \
    I2.I15.M17:1
saveOptions options save=selected
__________________________________________________________________________________________________
 Here is files generated in psf dir:
artil.log
logFile
mc1_ac1.montecarlo
mc1_dcOpInfo.montecarlo
mc1_element.montecarlo
mc1_outputParameter.montecarlo
mc1_separate
ipvs_ui.msg.log
mc1.mapping
mc1_dcOp.montecarlo
mc1_designParamVals.montecarlo
mc1_modelParameter.montecarlo
mc1_primitives.montecarlo
spectre.out
The "mc1_separate"is a dir containing sweep result files:
 -rw-r--r-- 1 workareas        0 Aug 20 10:40 ipvs_ui.msg.log
-rw-r--r-- 1 workareas     1231 Aug 16 21:31 logFile
-rw-r--r-- 1 workareas     4872 Aug 16 21:30 mc1_swp-000_ac1.ac
-rw-r--r-- 1 workareas     4036 Aug 16 21:30 mc1_swp-000_dcOp.dc
-rw-r--r-- 1 workareas  4012008 Aug 16 21:30 mc1_swp-000_dcOpInfo.info
-rw-r--r-- 1 workareas   183276 Aug 16 21:30 mc1_swp-000_designParamVals.info
-rw-r--r-- 1 workareas  4437996 Aug 16 21:30 mc1_swp-000_element.info
-rw-r--r-- 1 workareas 32983396 Aug 16 21:30 mc1_swp-000_modelParameter.info
-rw-r--r-- 1 workareas  1109648 Aug 16 21:30 mc1_swp-000_outputParameter.info
-rw-r--r-- 1 workareas    13935 Aug 16 21:30 mc1_swp-000_primitives.info.primitives
-rw-r--r-- 1 workareas     4872 Aug 16 21:31 mc1_swp-001_ac1.ac
-rw-r--r-- 1 workareas     4036 Aug 16 21:31 mc1_swp-001_dcOp.dc
-rw-r--r-- 1 workareas  4012008 Aug 16 21:31 mc1_swp-001_dcOpInfo.info
-rw-r--r-- 1 workareas   183276 Aug 16 21:31 mc1_swp-001_designParamVals.info
-rw-r--r-- 1 workareas  4437996 Aug 16 21:31 mc1_swp-001_element.info
-rw-r--r-- 1 workareas 32983396 Aug 16 21:31 mc1_swp-001_modelParameter.info
-rw-r--r-- 1 workareas  1109648 Aug 16 21:31 mc1_swp-001_outputParameter.info
-rw-r--r-- 1 workareas    13935 Aug 16 21:31 mc1_swp-001_primitives.info.primitives
-rw-r--r-- 1 workareas     4872 Aug 16 21:31 mc1_swp-002_ac1.ac
-rw-r--r-- 1 workareas     4036 Aug 16 21:31 mc1_swp-002_dcOp.dc
-rw-r--r-- 1 workareas  4012008 Aug 16 21:31 mc1_swp-002_dcOpInfo.info
-rw-r--r-- 1 workareas   183276 Aug 16 21:31 mc1_swp-002_designParamVals.info
-rw-r--r-- 1 workareas  4437996 Aug 16 21:31 mc1_swp-002_element.info
-rw-r--r-- 1 workareas 32983396 Aug 16 21:31 mc1_swp-002_modelParameter.info
-rw-r--r-- 1 workareas  1109648 Aug 16 21:31 mc1_swp-002_outputParameter.info
-rw-r--r-- 1 workareas    13935 Aug 16 21:31 mc1_swp-002_primitives.info.primitives
-rw-r--r-- 1 workareas     4872 Aug 16 21:31 mc1_swp-003_ac1.ac
-rw-r--r-- 1 workareas     4036 Aug 16 21:31 mc1_swp-003_dcOp.dc
-rw-r--r-- 1 workareas  4012008 Aug 16 21:31 mc1_swp-003_dcOpInfo.info
-rw-r--r-- 1 workareas   183276 Aug 16 21:31 mc1_swp-003_designParamVals.info
-rw-r--r-- 1 workareas  4437996 Aug 16 21:31 mc1_swp-003_element.info
-rw-r--r-- 1 workareas 32983396 Aug 16 21:31 mc1_swp-003_modelParameter.info
-rw-r--r-- 1 workareas  1109648 Aug 16 21:31 mc1_swp-003_outputParameter.info
-rw-r--r-- 1 workareas    13935 Aug 16 21:31 mc1_swp-003_primitives.info.primitives
-rw-r--r-- 1 workareas     3432 Aug 16 21:31 mc1_swp_ac1.sweep
-rw-r--r-- 1 workareas     3432 Aug 16 21:31 mc1_swp_dcOp.sweep
-rw-r--r-- 1 workareas     3436 Aug 16 21:31 mc1_swp_dcOpInfo.sweep
-rw-r--r-- 1 workareas     3444 Aug 16 21:31 mc1_swp_designParamVals.sweep
-rw-r--r-- 1 workareas     3436 Aug 16 21:31 mc1_swp_element.sweep
-rw-r--r-- 1 workareas     3444 Aug 16 21:31 mc1_swp_modelParameter.sweep
-rw-r--r-- 1 workareas     3444 Aug 16 21:31 mc1_swp_outputParameter.sweep
-rw-r--r-- 1 workareas     3440 Aug 16 21:31 mc1_swp_primitives.sweep
questions:
1. why the "export" was not executed?
2.  how to plot an expression from resultsdirectory?
what i am trying to achieve is do a DC followed by an AC within each MC run and nested with a sweep of a parameter.
 appreciate any feedbacks.
    I don't understand. In your original post, you had a sweep within monte carlo (sweeping EQ from 0 to 3 in steps of 1). That would do 4*100 simulations. In a later append, you said that you wanted the measurements at each value of EQ for each monte carlo point, so that's inherently iterations*sweep_points.
    So what are you really trying to do?
    Note that the actual number of invocations of the simulator will be dependent upon the setting of the "number of jobs" in ADE XL. With the corner sweep approach, the simulator will be invoked (at least) once per corner. With a sweep of 0:1:10, if the number of jobs is less than 11, you'll get 11 jobs each running 100 MC iterations - some in parallel if you have asked for more than 1 job. If you'd asked for 22 jobs, you'd get 22 simulations in parallel, each running 50 MC iterations, etc. This is assuming you only have a single test.
    If you are trying to run 100 MC iterations total, but include the effect of varying EQ, you could always define a statistics block in an include file to define the variation of the variable EQ (maybe with a uniform distribution - maybe you vary another variable with a continuous  uniform variation, and then set EQ to be the int(contVar) if it has to be an integer). That way you'd then include random values for EQ - although I'm not entirely sure that's terribly useful (it depends on what you really are trying to measure).
