  3. operating points implementation (verilogA and CDF)
  • Subscribers 129
  • Views 14120
Fabb
Fabb over 12 years ago
I am developping a verilog A model (with 2 sections analysis("tran") & analysis("dc")), with multiples internal variables declared  whith 'real' statment in verilogA code.
real x1,x2,x3,x4,x5;
In the CDF, I declare only X1 and X2 as operating points, and sometimes in ADE all the varialbes (X1 --> x5)  are reported.
Why?
Fab
    Did you turn on saveahdlvars?
  • Fabb
     Andrew,
    I set saveahdlvars=selected or saveahdlvars=all, the result is the same, all the varaiable are reported instead of only 2.
    Fab
    Yes, that's expected. Whilst saveahdlvars can be set to selected, there isn't actually a mechanism to select which variables to save. So it saves all of them.
