  3. How to search for vias with rows or columsn property in...
  • Subscribers 130
  • Views 15724
How to search for vias with rows or columsn property in layout XL
pham777
pham777 over 12 years ago
I am using IC615.06.15.151. In virtuoso layout XL, I opened a Find/Replace form, search for via in current cellview with
via definition == M5_M4
property Name CutRows == 2
But can not find any , eventhough there are  a lot of vias like that in layout. Do I make any mistakes ??
ha
  • theopaone
    theopaone over 12 years ago
     The attribute is cutRows, not CutRows.
    Try this:
    viaHeaders = setof( vh deGetCellView()~>viaHeaders
                                      vh~>viaDefName == "M5_M4"  && vh~>cutRows == 2 )
    viaInstances = viaHeaders~>vias
    Ted
  • pham777
    Thanks for your skill code, Ted. I tried it, but it still return nill. Maybe I typed it wrong. I believed the results will be something like
    db:0x0000x....How can I use that to select the vias in layout. I am not good at all about skill code.
    ha
    There's a mistake in Ted's code - you can't do ~>cutRows on a viaHeader object. You can do that on a via instance, but not a viaHeader. So instead you'd need to do:
    ; take car, because there should only be one match
    viaHeaders = car(setof( vh deGetCellView()~>viaHeaders
                                      vh~>viaDefName == "M5_M4"  && cadr(assoc("cutRows" vh~>overrideParams)) == 2 ))
    foreach(via viaInstances geSelectFig(via))
    This will select the vias afterwards.
    I think you should also contact customer support to request that you can specify cutRows/cutColumns etc in the search criteria for finding vias on the Find command (it doesn't work, because it's not a "property").
    Kind Regards,
  • pham777
    Thanks, Andrew. Your code works. But it returns only one match. Is it possible to return more than one match ?
    I will try to contact customer support.
    best regards,
    ha
    Sorry, I was being a bit stupid. I forgot you'd likely have more than one M5_M4 viaHeader with that number of cutRows...
    Change the code to:
    foreach(viaHeader viaHeaders
      foreach(via viaHeader~>vias geSelectFig(via))
  • pham777
    It works perfect now. You're the man.
    Appreciated,
    ha
