  3. ADEXL: backannotation of transient operating points for...
  • Subscribers 130
  • Views 15256
ADEXL: backannotation of transient operating points for montecarlo points
spectrallypure
spectrallypure over 12 years ago
Hi all! Could anybody please tell me how can I backannotate transient operating points in ADEXL for single montecarlo points? I am able to do it in "Single Run, Sweeps and Corners" mode, but when I switch to "Monte Carlo Sampling" mode, the  "Annotate->Transient Operating Points" option goes grayed-out. I have tried the montecarlo option "Save Data to allow Family Plots" but it doesn't change anything. I can see in the output log of the points that spectre is saving the data for the specified "infotimes" values, so I guess the information is there, it's just that I am not able to backannotate it to the schematic.
I really need this option for debugging failing montecarlo points. If for some reason this were not possible, would there be any way of taking the netlist of the failing montecarlo point and simulate it separately, say, using ADEL?
Thanks in advance for any help!
 Cheers,
 Jorge.
P.S. I am using  ADE version IC6.1.5.500.16.2 with spectre 10.1.1.218.isr14
  • Frank Wiedmann
    Frank Wiedmann over 12 years ago
    Have you tried creating a statistical corner from the montecarlo point and repeating the simulation in corner mode (see page 27 of http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=wp;q=ApplicationNotes/Custom_IC_Design/Stat_Quick_Start_615isr15.pdf)?
    This was a bug in the simulator - it was not writing the results correctly if using infotimes on a transient  within a monte carlo (I think statistical corner would have the same problem, since it's just a single point monte carlo). I can't quite remember when it was fixed, but I think it was in MMSIM121 ISR8 (or 9). So using the latest MMSIM121 ISR would be sensible.
    There is a remaining issue - you have to ensure that you have at least one "info" analysis enabled on the Save All form (this is CCR 1183683). That should hopefully get fixed soon (it's a relatively new CCR, but should be straightforward to fix).
  • spectrallypure
    Thanks so much for the suggestions, guys; changing to spectre version 12.1.1.048 did the trick! :)
    (Sorry for the late reply!)
    Cheers,
    Jorge.
