  3. Abstract Generation Crashes during Step pins in a given...
  • Subscribers 129
  • Views 13650
Abstract Generation Crashes during Step pins in a given cell
jorenrefuerzo
jorenrefuerzo over 12 years ago
whenever i try to run this given cell , the abstract generation run experience system crash.
heres the part of log file.
 WARNING   (ABS-523): Cell misc_dtr: The pin iptat20u has shape on an invalid user layer numbered 25 in the technology file. The pin will be deleted from the layout.
INFO (DB-170018): (dbPanic) dumping stack
abstract:dbPanic+221()
libvirtuos_sh.so:voDoAbortFuncs+37()
libvirtuos_sh.so:voSigAbortInfo+220()
:__kernel_rt_sigreturn+0()
abstract:_ZN9PcsCoPins21createPinsFromRoutingEP9PcsDbViewjj+1336()
abstract:_ZN9PcsCoPins24processExistingTerminalsEP9PcsDbView+2917()
abstract:_ZN9PcsCoPins10createPinsEP9PcsDbView+151()
abstract:_ZN5PcsCo4pinsEP9PcsDbView+128()
abstract:_ZN9PcsDbStep8runBasicEP9PcsDbCell+347()
abstract:_ZN9PcsSyStep8runBasicEP9PcsDbCell+99()
abstract:_ZN9PcsSyStep5runToEPS_P9PcsDbCell+180()
abstract:_ZN5PcsSy16runSelectedCellsEP9PcsSyStepS1_+130()
abstract:_ZN5PcsSy7runStepEPKc+469()
abstract:_ZN5PcsSy3runEPKc+201()
abstract:_ZN5PcsSy8abstractEv+25()
abstract:_wrap_skill_PcsElAPI_absAbstract+35()
libil_sh.so:iliVcodeEval2+10851()
libil_sh.so:ilxSkillEval2+220()
libil_sh.so:ilxSkillEval+37()
libil_sh.so:ilEMTopLevel+566()
abstract:_ZN16PcsElInterpSkill11evalCommandEPKc+322()
abstract:_ZN5PcsEl10loadReplayEPKc+1319()
abstract:_ZN5PcsEl6replayEPKc+93()
abstract:_ZN5PcsUi3runEv+858()
abstract:main+97()
INFO (DB-120006): System crashed, you can use dbOpenPanicCellView() to open saved cellViews.
 Hope you can help me solve this problem
Thanks.
  • ColinSutlieff
    ColinSutlieff over 12 years ago
    I assume that the first warning message is the cause of the crash. Otherwise you will need to send your data to the hotline for debugging.
    Your data contains shapes on a layer that is not recognized by your technology library.
    In other words, it is incompatible with your technology library.
    The shape is on a layer with a layer I.D.
    Normally, the technology library will provide a real layer name for this I.D.
    There is none in this case.
    This data has obviously been converted incorrectly from another source.
    You may need to repost to provide more information about where this data came from.
    Colin
