  3. Harmonic balance GMRES Warnnings
  • Subscribers 130
  • Views 15367
RFStuff
RFStuff over 12 years ago
Dear All,
I got follwing wrannig while doing PAC with HB analysis.My HB-PSS setting is as below:-
 analysis('pss ?engine "Harmonic Balance"  ?flexbalance "yes"  ?oversamplefactor "2"
        ?fund "2.5G"  ?harms "60"  ?errpreset "conservative"  ?tstab "50n"
        ?oscana t  ?p "/V15"  ?n "/gnd!"  ?oscmethod ""
        ?step ""  ?maxstep "0.4p"  ?write ""  ?writefinal ""
        ?swapfile ""  ?checkpss ""  ?method "gear2only"  ?tstabmethod "gear2only"
        ?relref "alllocal"  ?lteratio "10"  ?steadyratio "0.00001"  ?maxacfreq "200G"
        ?ppv ""  ?backtracking ""  )
 option(    'iabstol  "1e-13"
    'vabstol  "3e-8"
    'reltol  "1e-6"
converge( 'ic "/V2" "1.3" )
temp( 27 )
 Warning: GMRES did not converge to the desired tolerance of 1e-08. It actually converged to 0.000335882. The solution may not be accurate but it's saved anyway.
Could anybody please tell why this warnning is arising.
Is it safe to ignore ?
Kind Regards,
    Please look at these two solutions - solution 11842556 and solution 11812142.
    Kind Regards,
  • RFStuff
    Thanks for your reply.
    My spectre version is:-
     sub-version  12.1.0.402.isr5
    Looks like I have to file a SR
  • Tawna
    Tawna over 12 years ago
    Try downloading the latest MMSIM 12.1.1 version from http://downloads.cadence.com .
    If that doesn't fix the issue, then definitely please file a SR.
    best regards,
    Tawna
