  3. spectre commandline gives : -1.11111e+36 as a result. ERROR...
  • Subscribers 129
  • Views 1984
spectre commandline gives : -1.11111e+36 as a result. ERROR (SPECTRE-8003): mc1_subckts: Error evaluating ocean expression
samung
samung over 12 years ago
I am encountering an issue when I launch some simulations with this commandline :
spectre simulations/design_test/montecarlo/$i/input.scs +log simulations/design_test/montecarlo/$i/mc_log_file.log
The $i value is the value for different path corresponding to different netlists to launch MC on.
In the result file I have the value : -1.11111e+36
Example : in my mcdata result file :
-1.11111e+36 -1.11111e+36 -1.11111e+36 -1.11111e+36 -1.11111e+36
Instead of something like :
0.23 0.87 1 0
I suspect a synchronisation issue between the result waveforms creation and the ocean export commands.
If I relaunch the command, it works well.
I think I have a solution, it's to launch a spectremdl command, but I wanted to highlight this weird behaviour, and i would like to know if i can change something slight to make it work better, jus with a spectre commandline?
In the log file :
Warning from spectre during Monte Carlo analysis `mc1'.
    WARNING (SPECTRE-16002): Monte Carlo iteration 49 terminated prematurely because of the following error(s):
Error found by spectre during Monte Carlo analysis `mc1'.
    ERROR (SPECTRE-8003): mc1_subckts: Error evaluating ocean expression `expression_1=value(v("out_b_iv" ?result "tran") 4.775n)'.
    ERROR (SPECTRE-8003): mc1_subckts: Error evaluating ocean expression `expression_2=value(v("out_iv" ?result "tran") 4.775n)'.
    ERROR (SPECTRE-8003): mc1_subckts: Error evaluating ocean expression `expression_3=value(v("state_left" ?result "tran") 9.825n)'.
    ERROR (SPECTRE-8003): mc1_subckts: Error evaluating ocean expression `expression_4=value(v("state_right" ?result "tran") 9.825n)'.
Extract of the netlist :
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27  tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5  digits=5 cols=80 pivrel=1e-3 sensfile="../psf/sens.output"  checklimitdest=psf
mc1 montecarlo numruns=1 seed=12345 variations=mismatch sampling=standard  donominal=no scalarfile="../monteCarlo/mcdata" savemismatchparams=yes  mismatchparamfile="../monteCarlo/mismatchparam" mismatchscalarfile="../monteCarlo/mismatchdata"  dumpdependency=mismatch dependencymapfile="../monteCarlo/mismatchdependency" dut=[ I0 I1 M2 M0 M1 ]  savefamilyplots=no savedatainseparatedir=yes  firstrun=50 {
tran tran stop=34.40nn write="spectre.ic" writefinal="spectre.fc"  annotate=status maxiters=5
subckts info what=subckts  where=rawfile
export expression_1=oceanEval("value(v(\"out_b_iv\" ?result \"tran\") 4.775n)")
export expression_2=oceanEval("value(v(\"out_iv\" ?result \"tran\") 4.775n)")
mcOptions options genmcdep=yes
save out_b_iv out_iv out_b out state_left state_right
saveOptions options save=selected subcktprobelvl=2
Thanks a lot !!
P.
     Two things:
    1. What version of spectre are you using? (type "spectre -W")
    2. What does the artil.log file contain?
  • samung
    thanks a lot for the quick reply.
    1. spectre version : sub-version  10.1.1.181.isr12
    2. As far as now, I see the artil job with a "top" command to monitor the jobs. However, I don't have the artil.log, I think it is not created by default ?
    Example of command I launch :
    qs -q -p /home/.../script_spectre_mc_153.sh
    the /home/.../script_spectre_mc_153.sh contains :
    spectre simulations/.../153/input.scs +log simulations/.../153/mc_log_file.log
    P.
  • samung
    Hello Andrew,
    I tried to implement a spectremdl mc simu :
    spectremdl -batch simulations/.../montecarlo/1/input.mdl -design simulations/.../montecarlo/1/input.scs -measure simulations/.../montecarlo/1/montecarlo/mcdata +log simulations/.../montecarlo/1/mc_log_file.log
    and, I have in the log file simulations/.../montecarlo/1/mc_log_file.log :
    Analysis `montecarlo' is not supported in measurement aliases. Ignored
    Notice from spectre during Monte Carlo analysis `run_mc_simu', during task `MDLControl'.
        Out of 260 defined mismatch parameters, 252 is not referenced. There are 60 mismatch instances.
    Warning from spectre during Monte Carlo analysis `run_mc_simu', during task `MDLControl'.
        WARNING (SPECTRE-16006): run_mc_simu: Redundant monte carlo analysis was encountered. Neither scalar data nor waveform data will be saved.
    spectre completes with 0 errors, 7 warnings, and 4 notices.
    Is it possible to launch a spectremdl simulation for a mc analysis ? If no, how can i do to solve my synchonization issue (cf. above) ?
    Extract of the input files :
    input.mdl :
    /* mdl measurement file */
    alias measurement run_mc_simu {
    run mc1
    export real out_b_iv_cmos_operation_1 = V(out_b_iv)@4.775n
    run run_mc_simu
    input.scs :
    include "/home/.../_graphical_stimuli.scs"
    simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=70  tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5  digits=5 cols=80 pivrel=1e-3 sensfile="../psf/sens.output"  checklimitdest=psf
    mc1 montecarlo numruns=1 seed=12345 variations=mismatch sampling=standard  donominal=no  dumpdependency=mismatch dut=[ I0 I1 M2 M0 M1 ]  savefamilyplots=no savedatainseparatedir=yes  firstrun=1 {
    Thanks a lot !!
    P.
    PS : i don't have any artil.log file
  • samung
    • I was wondering, if I can implement a "wait/tempo/after 0.5s" (0.5s for examle) period between the end of the simulation and the export for the montecarlo simulation.
    I cannot find anything in the manual :
    Virtuoso® Spectre® Circuit Simulator
    Reference Product Version 10.1.1 June 2011
    Indeed, over 10000 mc simu, roughly 30% are impacted by this synchronization issue (the -1.11111e+36 as a result of error evaluating ocean expression), so I have to "relaunch" the impacted cases (and generally for most of them it works fine).
    • Plus, if you have a tip regarding how I can catch the artil.log file (which corresponds to the writing operation in the scalarfile/mcdata) after the mc simulation)
    Best Regards !!
    P.
