  3. IO placement
  • Subscribers 130
  • Views 13914
IO placement
Shameel
Shameel over 12 years ago
 Hi All,
 I have implemented a digital block in transistor level using virtuoso 6.1.5 . I want to do the IO placement for it. The IO library that I had has the following files in it.
--> <folderPath>/BackEnd/
* LEF P & R model             (in <folderPath>/BackEnd/lef)
  - FOA0I_R33_T33_GENERIC_IO_ANT_V55.3.lef
  - FOA0I_R33_T33_GENERIC_IO_ANT_V55.lef
  - foa0i_r33_t33_generic_io.3.lef
  - foa0i_r33_t33_generic_io.lef
  - header3_V55.lef
* physical compiler database  (in <folderPath>/BackEnd/phycompiler)
  - foa0i_r33_t33_generic_io.3.pdb
  - foa0i_r33_t33_generic_io.3.plib
--> <folderPath>/TECH/
* Cadence DFII environment files       (in <folderPath>/TECH/dfii)
  - FOA0I_R33_44.tf
  - cellout.tab
  - display.drf
  - layer.DEFINE
  - pg_sout3.tab
  - pg_sout4.tab
  - streamOut.map
  - streamin.tab
  - txtfont.tab
Which is better out of the two options
1. Do IO placement in virtuoso itself
2. Take it to encounter -  (How to do it ?)
Thanks,Shameel
  • Quek
    Quek over 12 years ago
    Hi Shameel
    You can use IOplacer from Virtuoso Floorplanner to do the placement. Please post the question in the Encounter forum to get some help on doing IO placement in Encounter.
    Best regards
    Quek
