  3. verilogA encryption for spectre
  • Replies 13
  • Views 25277
Fabb
Fabb over 12 years ago
I would like to encrypt a compact analog model written in verilogA and executed with spectre and ultrasim.
In the spectre doc, I found that a netlist could be encrypted wtih
spectre_encrypt [-i input_file] [-o output_file] [-all]
but what about a verilogA file?
Fabrice
    Andrew Beckett over 6 years ago in reply to Amar Kumar
    Hi Amar,
    You can't use spectre_encrypt for Verilog-A; this is for encrypting spectre netlists. For Verilog-A you need to use the xmprotect (ncprotect in older versions) that's in <SPECTREinstDir>/tools.lnx86/bin as described in this article: How can I encrypt a verilogA module ?
    In essence, something like:
    xmprotect -extension vap -language vlog -autoprotect mymodule.va
  • Saloni Chhabra
    Saloni Chhabra over 6 years ago in reply to Amar Kumar
    Also, it looks like you are including a *.v file (Verilog) in Spectre - this will not work. You need to use a Verilog-A model in a Spectre simulation.
    Saloni
  • Amar Kumar
    Amar Kumar over 6 years ago in reply to Saloni Chhabra
    Hi Andrew, Saloni,
    Thank you very much for your reply.
    I tried with "ncprotect", but it was failing because of syntax issue.(Older version may be as Andrew mentioned).
    With "xmprotect" , it worked great.
    Thanks again for your help.
    Amar
