  3. How to convert cellviews from IC5141 to IC615
  • Subscribers 129
  • Views 14113
tmart
tmart over 12 years ago
We've just converted from IC5141 to IC615. I'd like to re-use some old designs; how can I convert cellviews designed with IC5141 to be used in IC615?
Cheers,
Tore
    This is done using cdb2oa - which is also available via Tools->Conversion Toolbox in the CIW. It's also covered in the documentation (use the Help menus in Virtuoso to launch this, then search for cdb2oa).
  • tmart
    OK, found it! Thanks for your support! -T
