  3. Fast click and drag (zoom) command being interpreted as...
  • Subscribers 130
  • Views 15946
Fast click and drag (zoom) command being interpreted as a click (repeat) command......
ClintMeyer
ClintMeyer over 12 years ago
In my current setup I use right click and drag for zooming in.  I hold the right mouse button and drag to draw a box and when I release the mouse I will zoom into the box I have created.
I am noticing that if I execute a very fast zoom box, cadence will interpret my drag as a right mouse click and therefore execute my right mouse click command rather than my right mouse click drag command.  In my current setup right click executes a repeat command (cadence default in our installation).
I would like to remove the right click cadence default bindkey in hopes that Cadence will not interpret my click, drag and release as a right click rather my intended click, drag and release.
I did the same thing in Cadence 6.x and no matter how fast I was able to click and drag it never interpreted my click and drag as a plain click and release.
There seems to be a time sensitivity to whether a click and release is a click or drag command.  I can move the mouse rather far in the short time that is still inside the "click" time window.
Is there a cdsenv variable that sets up click time?
  • skillUser
    skillUser over 12 years ago
    Hi Clint,
    Yes there is an environment variable to control the double-click time:
    ui  dblClkTime     int     200
    Double Click Time is given in milliseconds. 200 ms is 1/5th of a second. If the program receives a second mouse click in the window of time defined by Double Click Time, the action is taken as a double-click.
    This is also controlled from the UI under Options -> User Preferences, Double Click Time (a slider controls the value) .
    Hopefully this is what you are looking for?
    Lawrence.
  • Frank Wiedmann
    Frank Wiedmann over 12 years ago
    You might also want to take a look at http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11840198.
  • ClintMeyer
    Lawrence
     Unintuitively that works, I saw that option but did not try it since I was not doing a double click.  THANKS FOR THE TIP!!!!
     Clint
  • ClintMeyer
    Thanks for pointing me towards that, looks like I am not alone.  Thankfully the double click time worked.
