  3. abstractgen error (abs-1427 and ABS-520)
  • Subscribers 129
  • Views 13365
jorenrefuerzo
jorenrefuerzo over 12 years ago
Hi ,
 I'm having this error int the Pin creation part. Can anyone tell me how to overcome this?..
11/28/13 18:52:23: ERROR     (ABS-1427): Could not create pin from shape because
11/28/13 18:52:24: ERROR     (ABS-520): Cell pcs_dual: database could not create net named VSS.Verify the permissions on the design and ensure that the write permission exists.
 the Version Im using is  IC6.1.5.500.16.2
    This might be the same issue as CCR 1123356 which is due to be fixed in the IC617 release, but it wasn't that clear to me. So I would suggest you contact customer support and then we can take a proper look at your data.
    Kind Regards,
