  3. ERROR (VACOMP-1008): Cannot compile ahdlcmi module library...
  • Replies 11
  • Views 23389
VoTuanMinh
VoTuanMinh over 12 years ago
Hi all,
I am a new commer to Cadence, when I tried to simulate with Veriloga, I got the Error as follow:
ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB/1085_Minh_SAR_12bit_BST_Switch_veriloga_veriloga.va.BST_Switch.ahdlcmi/Linux/../ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
ERROR (SFE-91): Error when elaborating the instance BST_Switch. Simulation should be terminated.
And here is the content of the "ahdlcmi.out"
ahdlcmicompile: Compiling ahdlcmi in input.ahdlSimDB/1085_Minh_SAR_12bit_BST_Switch_veriloga_veriloga.va.BST_Switch.ahdlcmi/Linux/ for Linux with optimize using gcc on Mon Jun  2 17:22:04 ICT 2014 [5.0]
ahdlcmicompile: Generating makefile
PATH:  /usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.1/install/bin:/usr/bin/Cadence/IC614-500-13/bin:/usr/bin/Cadence/IC614-500-13/tools/bin:/usr/bin/Cadence/IC614-500-13/oa_v22.04.073/bin:/usr/bin/Cadence/MMSIM11-10-228/tools/bin:/usr/bin/Cadence/IC614-500-13/share/cdsdoc/bin:/usr/bin/Cadence/IC614-500-13/share/bin:/usr/bin/Cadence/IC614-500-13/tools/spectre/bin:/usr/bin/Cadence/IC614-500-13/tools/dfII/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
LD_LIBRARY_PATH:  /usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.1/install/lib:/usr/bin/Cadence/MMSIM11-10-228/tools/lib:/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/mdl/lib:/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/mmsim/lib:/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/inca/lib:/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/lib:/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/lib/SuSE:/usr/bin/Cadence/IC614-500-13/tools/lib:/usr/bin/Cadence/IC614-500-13/tools/lib/SuSE/SLES11:/usr/bin/Cadence/IC614-500-13/oa_v22.04.073/lib/linux_rhel40_32/opt:/usr/bin/Cadence/IC614-500-13/tools/QT/lib:/usr/bin/Cadence/IC614-500-13/tools/dfII/lib:/usr/bin/Cadence/IC614-500-13/tools/sev/lib:/usr/bin/Cadence/IC614-500-13/tools/inca/lib
Can't exec "mpstat": No such file or directory at /usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/bin/getCPUnum.pl line 41.
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/bin/gnumake -j2 -f GNUmakefile
Compiling C file BST_Switch_func.c (optimize) with -O0
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O0 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/include -c BST_Switch_func.c -o obj/optimize/5.0/BST_Switch_func.o || rm -f -f obj/optimize/5.0/BST_Switch_func.o
Compiling C file BST_Switch_DcFuncDerLoad.c (optimize)
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/include -c BST_Switch_DcFuncDerLoad.c -o obj/optimize/5.0/BST_Switch_DcFuncDerLoad.o || rm -f -f obj/optimize/5.0/BST_Switch_DcFuncDerLoad.o
/bin/sh: Illegal option -h
rm -f -rf BST_Switch_func.c
rm -f -rf BST_Switch_DcFuncDerLoad.c
Compiling C file BST_Switch_DcFuncLoad.c (optimize)
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/include -c BST_Switch_DcFuncLoad.c -o obj/optimize/5.0/BST_Switch_DcFuncLoad.o || rm -f -f obj/optimize/5.0/BST_Switch_DcFuncLoad.o
Compiling C file BST_Switch_TranFuncDerLoad.c (optimize)
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/include -c BST_Switch_TranFuncDerLoad.c -o obj/optimize/5.0/BST_Switch_TranFuncDerLoad.o || rm -f -f obj/optimize/5.0/BST_Switch_TranFuncDerLoad.o
rm -f -rf BST_Switch_DcFuncLoad.c
rm -f -rf BST_Switch_TranFuncDerLoad.c
Compiling C file BST_Switch_TranFuncLoad.c (optimize)
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/include -c BST_Switch_TranFuncLoad.c -o obj/optimize/5.0/BST_Switch_TranFuncLoad.o || rm -f -f obj/optimize/5.0/BST_Switch_TranFuncLoad.o
Compiling C file BST_Switch_cmi_c.c (optimize)
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/include -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cmi/include -c BST_Switch_cmi_c.c -o obj/optimize/5.0/BST_Switch_cmi_c.o || rm -f -f obj/optimize/5.0/BST_Switch_cmi_c.o
rm -f -rf BST_Switch_TranFuncLoad.c
rm -f -rf BST_Switch_cmi_c.c
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc -shared -O3 -fPIC -o obj/optimize/5.0/libahdlcmi.so ./obj/optimize/5.0/BST_Switch_func.o ./obj/optimize/5.0/BST_Switch_DcFuncDerLoad.o ./obj/optimize/5.0/BST_Switch_DcFuncLoad.o ./obj/optimize/5.0/BST_Switch_TranFuncDerLoad.o ./obj/optimize/5.0/BST_Switch_TranFuncLoad.o ./obj/optimize/5.0/BST_Switch_cmi_c.o  -m32 -Wl,-rpath,/usr/lib -Wl,-rpath,/lib -s
gnumake: *** [obj/optimize/5.0/libahdlcmi.so] Error 2
I read some Solved threads in this forum and tried to solve but I couldn't. (For e.x add "-64" in UsrOptionField)
Could anyone here please help me to solve this problem?
Thank you so much in advance.
Minh
    Andrew Beckett over 7 years ago in reply to qamar +1
    I don't see why it should make any difference whether you are using the OCEAN script from the CIW or from the terminal window (although perhaps it depends what you mean by that - normally running the …
    I don't see why it should make any difference whether you are using the OCEAN script from the CIW or from the terminal window (although perhaps it depends what you mean by that - normally running the "ocean" command is just running virtuoso without the graphical environment, so I'm not sure what you are doing here).
    Perhaps you should contact customer support rather than relying on my guessing what's wrong with your setup?
