  3. Using the Virtuoso autorouter: routing grid
  • Replies 12
  • Subscribers 133
  • Views 22583
RVERP
RVERP over 10 years ago
How do I set the routing grid? I can use the option to route on the routing grid, but I can't find how to check it's value, or how to set a new value.
I want to force the autoroute to place spines/vias on the exact grid I want, so I suppose the routing grid is what I have to use.
  • RVERP
    RVERP over 9 years ago
    Snap wires to is set to "Routing Grid"
  • Alex Soyer
    Alex Soyer over 9 years ago
    I assume you have added the routing pitch using PRE but at which level did you saved it ?
    At the design level or at the techfile level ?
    If it is in a specific constraint group please make sure you have this constraint active for the interactive routing in the Option > Editor Wire Edit Default Constraint Group
