  3. Trouble with ocean script for parametric analysis using...
  • Replies 11
  • Views 20684
Trouble with ocean script for parametric analysis using ADE L
saikatc
saikatc over 10 years ago
I am using ocean scripting for parametric analysis of my design. There I came across a strange issue. My interest is to vary the supply voltage for that I am using a variable called v_supply. For single simulation when I am assigning a value to that variable, it is working.
desVar( "v_supply" 300m)
But when I want to have a parametric analysis using the same, it is showing the following message.
*INFO* (icLic-25) License Analog_Design_Environment_GXL ("95220") was used to run ADE L.
The variable "v_supply" is not defined in the current
design.
I am using the following codes.
paramAnalysis("v_supply" ?values '(300 425 550 675 800 ))
paramRun ()
I also tried with
paramAnalysis("v_supply" ?start 300 ?stop 800 ?step 100)
paramRun ()
without any difference.
Any help will be appreciated.
Regards
Saikat Chatterjee
  • saikatc
    Sorry Andrew, my mistake. I understood the expression part wrong. It is actually working. Thanks a lot. Next I am going to try the abDumpWaveform feature. Thanks a lot for your help.
