  3. Official definition and formula for DC operating point ...
  • Subscribers 130
  • Views 17563
Official definition and formula for DC operating point parameters
BaaB
BaaB over 9 years ago
It took me a lot of time finding the definition and formula of operating point parameters in DC analyis. However, I couldn't find any official definition and formula explaining how these parameters are calculated.
I searched help by "spectre -h" and "cdnshelp" but these only give the name of these parameters not how they are calculated.
Could you tell me where can I find it?
Thank you.
  • Quek
    Quek over 9 years ago
    Hi Huan Ngugen
    Would you please have a look at $MMSIMHOME/doc/spectremod/spectremod.pdf and let us know if it contains the info which you need?
    Best regards
    Quek
  • BaaB
    Thank you.
    I looked at it and actually I don't find the formula explaining how these parameters are calculated.
    For example, section Operating-Point Parameters (page 1009):
    These are what I want to know so I list them here so they are not actually the order in the document.
    ids (A)                 Resistive drain-to-source current.
    betaeff (A/V2)    Effective beta.
    ron (Ohm)          On-resistance.
    id (A)                   Resistive drain current.
    As you can see, these are just the names not how they are calculated.
    This depends on the model you're using. For bsim4, recent versions of the documentation have added links between the operating point parameter lists (at the end of the chapter on bsim4 in the document Quek mentioned) to the appropriate equation (where relevant).
    So, which version of the simulator are you using? Which device model are you using?
