  3. ERROR (SFE-23): "input.scs" 14: N0 is an instance of an...
  • Subscribers 129
  • Views 6387
ERROR (SFE-23): "input.scs" 14: N0 is an instance of an undefined model nmos. Tried by adding simulator lang=spice in the first line of the model file
saikishore
saikishore over 9 years ago
Hello everyone,
I am new to cadence I am trying to simulate a basic inverter circuit using spectre but I am getting this error
ERROR (SFE-23): "input.scs" 14: N0 is an instance of an undefined model nmos. I saw several posts regarding the same problem I but none of those posts helped me, I already attached a model library file to it which is in spice format with extension .m and also tried by adding simulator lang=spice in the first line of the model file but I am getting the same error. I also tried by changing the extension to .scs and changing lang=spectre, however, I am getting a new error after this step. previously I did a simulation with tsmc13rf technology and model file written in spectre which worked perfect but I don't know why it was not working when I am trying to simulate spice model files (I got these from NSCU CDK beta version )
I am also attaching my netlist file and few lines of model library which I am using
.model NMOS_VTL nmos level = 54
+binunit = 1 paramchk= 1 mobmod = 0
+capmod = 2 igcmod = 1 igbmod = 1 geomod = 1
// Generated for: spectre
// Generated on: May 9 11:24:37 2016
// Design library name: test
// Design cell name: invertor_tb
simulator lang=spectre
global 0 vdd!
include "/home/kishore/ncsu-cdk-1.6.0.beta/models/spectre/standalone/ami06N.m"
include "/home/kishore/ncsu-cdk-1.6.0.beta/models/spectre/standalone/ami06P.m"
// Library name: test
// Cell name: invertor
// View name: schematic
subckt invertor A out
N0 (out A 0 0) nmos w=6u l=600n m=1 region=sat
P0 (out A vdd! vdd!) pmos w=12u l=600n m=1 region=sat
ends invertor
// End of subcircuit definition.
// Cell name: invertor_tb
I0 (A out) invertor
V0 (vdd! 0) vsource type=dc dc=1.2
V1 (A 0) vsource type=pwl delay=5.1n wave=[ 0 0 5n 0 ] noisefile="5"
C0 (out 0) capacitor c=1f m=1
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
checklimitdest=psf
tran tran stop=10n write="spectre.ic" writefinal="spectre.fc" \
annotate=status maxiters=5
Best regards,
kishore.
    Your model file defines a model called NMOS_VTL but your transistor instance is referring to a model called "nmos". That's why it doesn't work (the message is very clear...)
  • saikishore
    Thanks Andrew,
    I changed the value of nmos_vtl to nmos and the same thing for pmos, this time, I got a new error
    ERROR (CMI-2011): Unable to open noise file `5
    I suspect you need to change the model name on the instances you're using (I'm not sure where the components you are using are coming from or whether you have control over the model parameter) - you seem to be hacking model files instead.
    This new issue is probably because of this line in your netlist:
    I suspect  you accidentally typed in "5" in the noise file field on the source.
