  3. Print Noise Summary after "ANALYSIS DURING TRAN"
  • Replies 12
  • Views 15632
msharma
msharma over 9 years ago
I need to simulate the noise of my circuit at specific points in time after transient analysis. For this I use the "ANALYSIS DURING TRAN", (analysis->tran->options-?output->"ANALYSIS DURING TRAN"). I specifiy a time in actimes, and specify acnames = noise. The analysis runs successfully. However, I am unable to use the "Print Noise Summary" feature. When choosing Print Noise Summary, no dialog pops up, just an empty result window.
How can I use the "Print Noise Summary" feature when running noise analysis at specific tran points?
Mohit
    Renaming the output file name won't work - all that will happen is that you make the results inaccessible that way. It has to be consistent with what it's called in the logFile which is the "catalog" for the results.
    Are you saying that noiseSummary() worked OK and printed to the screen, but not if you specified ?output ? If so, try specifying ?output "./noise.txt" - i.e. put "./" at the beginning to make it write to the current directory. It's possible that you have your SKILL path set (getSkillPath()) so that the working directory is not at the beginning, and so a path without a directory component may get written to another directory.
    To be honest, spending more time trying to figure this out without seeing any data is a waste of time, when using a version without the bug is much more straightforward.
  • msharma
    OK, I will try to get hold of a newer version of MMSIM. Thanks for pointing at the issue.
    My problem with OCEAN function noiseSummary() is that, it never prints a noise summary (with or without a file name). It just prints a string t, which probably means boolean true. The function plot() does work on the selected noise results.
    Mohit
