  3. Referencing a model, not a model instance
  • Replies 12
  • Subscribers 132
  • Views 22945
itos
itos over 9 years ago
I found the post about disabling flicker noise with alter in this forum and I got it working:
turnOffFlicker1 alter mod=N15.xmmaster.lvtnfetacc param=nfalw value=0
turnOffFlicker2 alter mod=N15.xmmaster.lvtnfetacc param=nfblw value=0
turnOffFlicker3 alter mod=N15.xmmaster.lvtnfetacc param=nfclw value=0
If I reference the model (i.e. lvtnfetacc and masterlvtnfet from the model files) I get:
ERROR (SFE-1997): "disable_flicker.scs" 6: turnOffFlicker4: parameter `mod': Invalid model name `lvtnfetacc' was given as value of parameter `mod'.
I tried all possible variations. Unfortunately the model files are so nested that I don't know what's going on. Generally there is a subckt for "lvtnfet" which instantiates instance xmmaster of lvtnfetacc. lvtnfetacc itself is a subckt which instantiates m1. m1 is a reference to the model lvtnfetacc of type utsoi which has the parameter nfalw etc:
sub
Please help me to set nfalw to zero globally without listing all instances.
Also, is it possible to list multiple mod/param/value pairs at once so that I do not need to create thousands of turnOffFlickerXX lines that go up to 1000?
Thank you!
    SPECTRE161 is the continuation of MMSIM151. We had a name change between the releases - given that the MMSIM stream is mostly about Spectre simulation modes (Spectre, APS, XPS etc), it was deemed to be a more logical name. So yes, it replaces MMSIM completely.
    Glad the problem was resolved by SPECTRE161!
  • itos
    Andrew, thanks again for all your great and enduring help in this forum!
