  3. iterated instance with different views to use, hierarchy...
  • Subscribers 129
  • Views 15162
iterated instance with different views to use, hierarchy configuration
dani0815
dani0815 over 8 years ago
hi all,
I have an iterated instance e.g. ADC<0:9>. I am trying to switch views in the hierarchy editor such that ADC<0> is set to e.g. 'schematic' view and ADC<1:9> are set to e.g 'behavioral' view.
I have tried to browse the tree view in the hierarchy editor, but the iterated instances are listed on a single line, and such can only select 1 'view to use' for all iterated instances.
Is there a way to do such a hierarchy configuration?
Thanks for your help. Best Regards
Dani
-- cadence virtuoso IC6.1.7
    Dani,
    This cannot be done currently (unless you have two physical instances, one for ADC<0> and one for ADC<1:9>). There is a fairly major project to potentially offer limited support for this - you should contact your account team for more details.
  • dani0815
    hi Andrew,
    Thanks for your quick reply. I am currently using the method you mentioned, but will possibly see if I can get some support from the account team
    Regards
    Dani
