  3. Defining waveform thicknesses and colors on a white background...
  • Replies 16
  • Subscribers 127
  • Views 25324
Defining waveform thicknesses and colors on a white background in VIVA
CADcasualty
CADcasualty over 7 years ago
I'm trying to make viva look good using a white background and the default colors are kind of lousy (in my opinion). I read in the manual:
viva.graph colorBank string "default"
You can use this variable to customize the set of trace colors in a Virtuoso Visualization and Analysis XL session. The default value of this environment variable is the default color bank that is specified in the display.drf file.
Note: This variable does not change the colors defined in the display.drf file. Also, when you plot simulation results from ADE, the color bank from the display.drf file is honored.
The color names should be separated by a comma, a semicolon, or a space. The color name can be a list of colors defined in the SVG color keyword, such as steelblue, azzure, or the RGB hexadecimal value of the color in the #RRGGBB format.
viva.graph colorBank string "red; blue; green; yellow"
viva.graph colorBank string "#ff0000, #0000ff, #008000, #ffff00"
So I tried putting:
envSetVal("viva.graph" "colorBank" 'string "red blue green yellow")
into my .cdsinit but nothing about the waveform colors changed. Note that I have other viva related stuff in my .cdsinit that does produce changes in viva so I know that all works. I also note that the documentation says "when you plot simulation results from ADE, the color bank from the display.drf file is honored" which strikes me as a bit confusing i.e. even though I define the colorBank in .cdsinit does the display.drf file still take precedence? I did take a look at the display.drf file and couldn't figure out where/what the color bank was.
Regarding the waveform thicknesses, I find "fine" to be too thin and "medium" to be too thick (and obviously all the rest of the options just waay too thick). Is there a way to hack a file (maybe display.drf) where I can monkey with line thicknesses?
    Andrew Beckett over 7 years ago in reply to CADcasualty
    Well, you could just use drGetColor("display" "blue") to retrieve the data, So something like:
    (defun abDisplayColorToHex (colorName @optional (display "display"))
      (let (color)
        (setq color (drGetColor display colorName))
        (if color
          (sprintf nil "0x%02x%02x%02x" (nth 2 color) (nth 3 color) (nth 4 color))
          (abColorNameToHex colorName)
  • CADcasualty
    CADcasualty over 7 years ago in reply to Andrew Beckett
    Thanks once again! Your routine works like a charm. I did try to pass it a list (which abColorNameToHex can accept) but it didn't work. I took a stab at modifying abDisplayColorToHex to accept a list based on what I saw in abColorNameToHex but I confess the programming language just confuses me too much. Would you mind please?...
    I put them both in the same file and defined them in a similar fashion:
    /* abColorNameToHex.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jul 02, 2018
    Modified   Jul 10, 2018
    By         A.D.Beckett
    Convert friendly color (or colour!) names to RGB hex strings
    as suitable for passing to awvPlotWaveform. Invalid color names
    result in string when gets handled as black (or white) when plotting in
    ViVA.
    abColorNameToHex("pink") => "0xffc0cb"
    abColorNameToHex(list("yellow" "purple" "lightgreen")) =>
        ("0xffff00" "0xa020f0" "0x90ee90")
    Also provides abDisplayColorToHex which first looks for color
    names in the display.drf and if not found, uses abColorNameToHex.
    This also supports both a single color and a list of colors.
    Uses SKILL++ methods just to avoid having a case statement!
    SCCS Info: @(#) abColorNameToHex.il 07/10/18.17:25:52 1.2
    (defmethod abColorNameToHex ((colorName string))
      (strcat "0x"
              (buildString
                (mapcar
                  (lambda (intensity)
                    (sprintf nil "%02x" (round (times intensity 0.255))))
                  (nameToColor colorName)
    (defmethod abColorNameToHex ((colorNames list))
      (mapcar 'abColorNameToHex colorNames)
    (defmethod abDisplayColorToHex
      ((colorName string) @optional (display "display"))
      (let (color)
        (if color
      ((colorNames list) @optional (display "display"))
      (mapcar lambda((colorName) (abDisplayColorToHex colorName display))
              colorNames)
  • CADcasualty
    Thanks Andrew, however I do not see the new code working for the drf colors :-(
    So did you use abDisplayColorToHex or abColorNameToHex? I don't see why it would have worked for you before I changed the code to handle lists but not after...
  • CADcasualty
    Very sorry - pilot error on my behalf! I did in fact use the wrong routine name. I continue to be greatly indebted to you for all of your help. God help me whenever you retire...
