  3. Cadence Liberate Characterization Help
  • Replies 48
  • Views 42922
anurans
anurans over 8 years ago
Hi All,
For the characterization of a standard cell library, I am using LIBERATE_15.14.070 version. The cell spice model was generated using IC6.1.5, and I am using Spectre as the external simulator for the characterization. I have a question specifically on the leakage_power nodes of the .lib file generated by Liberate. For an example, for a simple inverter, I ended up having leakage_power values as follows (in the link):
https://pastebin.com/grfasa1s
However the resulting leakage values do not follow the circuit simulation values in IC6-Spectre.
> Can anybody explain why the leakage value related to VSS pin is always 0 ?
> How does the Liberate calculate these values ? Is there a way to evaluate the accuracy of Liberate-Spectre simulation ?
Thanks in advance
Anuradha
  • Guangjun Cao
    Guangjun Cao over 8 years ago +1
    Hi Anuradha, First of all, please move to the latest Liberate release, 17.1.3. When characterising leakage power, by default, the measured dc current will be multiplied by the supply voltage. This…
  • Guangjun Cao
    Guangjun Cao over 7 years ago in reply to fengye
    Fengye,
    1. R&D confirmed that there is no such a settings as char_library -extsim spectre-ski. Are you sure this is exactly what you used in the script? My understanding is spectre-ski is an internal settings, when SKI is enabled. This is NOT a directly specified by user.
    2. please switch to latest Liberate ASAP!
    3. Some times, the SKI option may not give correct results, due to Spectre version. In general, DO NOT load a Spectre module before your run. Let Liberate use its owb build-in mmsim or Spectre! When there a difference, R&D will need a full test case.
    4. for power calculation, I suggest you start with an invertor. Use this as an example to understand how witching power is calculated. then look at the another cell to debug. The raw expression =Total_charge_at_power_pin(current integration as shown in sim.sp)* related_Rail_ground_voltage_difference *0.5 - Load_index_2 * Voltage_swing_at_load^2 /capunit. This is equivalently an energy value. For debug, you should get the waveform of your standalone simulations with a simulator using the exact sim.sp. Then check if the waveforms are identical. if identical, this means there is no simulation issue. Next, you can focus on the measurement. For this, you need to check the waveform and the measurement statement in sim.sp. One common issue can be the end time is not correct when the tool integrate the current of powe supply. But this is very rare with Liberate. In most cases, it is due to circuit behavior and can be corrected with settings.
    Guangjun
  • fengye
    fengye over 7 years ago in reply to Guangjun Cao
    Thanks a lot. It's so kind of you to spend time to answer my questions. From what you said,
    1)For the default simulator, I think you are right. Because th results of using "-extsim ski" and just using the default setting are the same. Do you have a good way to make sure which is the default simulator?
    2)I will try to find the latest Liberat.
    3) As you have said, spectre may be a good choice for much correct result. That means I can use "char_libray -extsim spectre xxx", besides, what other setting should I make? I just want to verify my setting is true or false?
    4) I can't use spectre, so I use hspice to simulate the sim.sp. But it's too slow. In the sim.sp,
    ".param icap_tend6=2.0000000e-12
    .meas tran AltosCap6 INTEG i(VA) from='icap_tend0' to='icap_tend6'
    .param icap_tend7=2.2500000e-12
    .meas tran AltosCap7 INTEG i(VA) from='icap_tend0' to='icap_tend7'
    .meas tran AltosPower000 INTEG i(VVDD) from=0 to='power_tend'
    .meas tran AltosPower001 INTEG i(VGND) from=0 to='power_tend'
    .meas tran AltosBgnVoltage000000 FIND v(Z) AT=0.0
    .meas tran AltosEndVoltage000000 FIND v(Z) AT=tran_tend"
    In fact, the integration of current is Q, is it necessary to calculate the integral of input i(VA).
    fengye
  • Guangjun Cao
    You are welcome. And thanks for using Cadence tools.
    I will be on vacation from tomorrow afternoon UK time. So, I will not be available to help untill new year.
    the correct option char_library -extsim is spectre or hspice. No other options is legal.
    SKI issue can often happen with certain Spectre version. Sometime, you can try manually load a different Spectre version.
    If you use define_arc command, then add -user_arcs_only(for standard cells) or -io (for IO or custom-designed cells) mode.
    AltosCap is for pin cap measurement, ie. C=deltQ/deltaV. you example shows it is for pin A capacitance.
    AltosPower is for power calculation. In most cases, a simple cell should have power more or less independent of load index, if the load power is excluded, ie. -C * V * V is used in the expression. If you see trend like larger power for higher load(index-2), then your simulation time is too short. default, I think, is 1e-6s.
    when you do debug run, you can also use set_var debug_flow 1x1 or 2x2. This way, there is limited iter in the sim.sp, which makes the debug much easier. I normall start with 1x1.
    Guangjun
  • fengye
    Hi, Guangjun
    Thank you very much. According to you have said, I have  learned more information about liberate. Next, I will think more about you have told me.
    Thanks again,
    Hope you have a good vocation!
    fengye
  • Guangjun Cao
    Very glad that I have helped you.
    One correction to my earlier comments on power at higher index_2. it should be "lower power at high load may indicate insufficient simulation time".
    I also want to mention this, with Spectre, standalone simulation also generates a sim.measure file, in which results of all the measure is listed.
    Wish you a very happy new year!
    Guangjun
  • Guangjun Cao
    Guangjun Cao over 7 years ago in reply to Guangjun Cao
    in case you do not already have them, below are recommended settings for Spectre in Liberate
    # Spectre
    set_var extsim_cmd_option   "+spice +lorder MMSIM:PRODUCT +aps -mt +rcopt=2 +liberate"
    set_var extsim_deck_header  "simulator lang=spectre\nOpt1 options reltol=1e-4\nsimulator lang=spice"
    set_var extsim_leakage_option     "method=gear gmin=1e-15 gminfloatdefault=gmindc redefinedparams=ignore rabsshort=1m limit=delta save=nooutput"
    set_var extsim_option       "method=gear gmin=1e-15 gminfloatdefault=gmindc redefinedparams=ignore rabsshort=1m limit=delta save=nooutput"
    set_var extsim_tran_append      "lteratio=10 ckptperiod=1800"
    set_var extsim_reuse_ic           3
    # Licensing
    set_var spectre_use_char_opt_license 1
    ## Spectre-SKI
    set_var ski_enable          1
    set_var ski_clean_mode      2
    set_var extsim_use_node_name 1
    set_var extsim_save_passed  none  ; # Do not save the decks with SKI as the disk storage requirement is too high
    set env(TMPDIR) "$env(PWD)/ski_temp"    ; # Put SKI tmp files here
    # Use compatible methodologies between Alspice, SKI, and Spectre ###
    # Standardize transient window
    set_var power_sim_estimate_duration     1
    set_var power_tend_match_tran           1
    set_var tran_tend_estimation_mode 1
    # Match SKI methodologies to Spectre
    set_var ski_alter_mode            3
    set_var ski_mdlthreshold_exact          1
    set_var ski_power_subtract_output_load_match_extsim 1
    # Match Alspice methodologies to Spectre
    set_var alspice_power_subtract_output_load_match_extsim      1
  • fengye
    Hi,Guangjun,
        I really appreciate you. When you have started your vocation, you still remember my question and provide help to me. It's so kind of you. Above command setting will help me to check my setting for using external simulator.
       Have a good vocation!
    Best wishes!
    fengye
  • anurans
    anurans over 7 years ago in reply to Guangjun Cao
    Hi Guanjun, I made a post on Liberate in Custom IC design forum. Could you please kindly take a look at it ?
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/40918/cadence-liberate-characterization-of-complex-logic-cells
