  3. QRC: *Error* load: can't access file "[...]/ext_18.12.000...
  • Replies 14
  • Views 9571
QRC: *Error* load: can't access file "[...]/ext_18.12.000/tools/extraction/bin/32bit/etc/context/6.1.0/qrc.ini"
dontpanic
dontpanic over 7 years ago
Hi! When I launch the "PVS->Run LVS..." command in a layour editor, I get the following messages in the CIW:
*WARNING* (DEBASE-102079): A SKILL error occurred in function CCSSetupQRC
In my QRC installation the "[...]/32bit" directory does not exist, but the "[...]/64bit" does. Moreover, I have the environment CDS_AUTO_64BIT variable set to ALL, but it seems CCSSetupQRC is looking for the wrong executable. How can I solve this issue? I am using ICADV12.3-64b.500.17 with PVS 16.12
Thanks and regards, Jorge.
  • Quek
    Quek over 7 years ago in reply to dontpanic
    Hi Jorge
    The SKILL procedure is just for presetting some values in the Quantus form. If you have checked and ensured that the form settings are correct, the error which you had encountered should not affect the extraction results.
    Would it be possible for you to share the outputs of the following 2 cmds?
    pp(CCSSetupQRC)
    pp(vuiUserDefinedRCXFormSetupCB)
    Best regards
    Quek
  • dontpanic
    dontpanic over 7 years ago in reply to Quek
    Thanks for your reply Quek; please find below the output of the commands; indeed, it seems the 32bit directory is hardcoded in my setup!
    ...is it maybe possible to correct that path to the right (existing) directory (64bit)?
  • Quek
    Hi Jorge
    Would you please try the following and let us know if it helps?
    a. Open a new text file named "CCSSetUpQRC_mod.il"
    b. Add the following lines in it:
    procedure( CCSSetupQRC(@rest dmy)
       let( (ext_path qrcini_loc verInfo ver)
          ext_path=getShellEnvVar("QRC_HOME")
          unless( ext_path error("QRC_HOME shell variable cannot be found"))
          verInfo=getVersion('subVer)
          pcreMatchp("IC(\\S+)-" verInfo)
          ver=pcreSubstitute("\\1")||"6.1.0"
          qrcini_loc=sprintf(nil "%s/tools/extraction/bin/64bit/etc/context/%s/64bit/qrc.ini" ext_path ver)
          load(qrcini_loc)
          qrcMenu~>qrcRunCalibreItem~>_itemCallback="CCSCustomQRCSetup()"
       ) ;let
    ) ;procedure
    procedure( vuiUserDefinedRCXFormSetupCB(form)
       prog( (runDir)
          when( form~>hiFormSym=='vuipreRcxForm
             form~>runName~>value="Design"
             if( hiIsForm('preRCXQueryUI) then
                runDir=sprintf(nil "%s/%s" pwd() preRCXQueryUI~>queryRunDir)
             else
                runDir=sprintf(nil "%s/%s" pwd() form~>runName~>value)
             ) ;if
             form~>runDir~>value=runDir
          ) ;when
          return(t)
       ) ;prog
    ) ;procedure
    c. Load it in CIW using:
    load "./CCSSetUpQRC_mod.il"
    I think it should resolve the problems. : )
    Best regards
    Quek
  • dontpanic
    Thanks again for your reply, Quek; I still get the same error:
    QRC: *Error* load: can't access file "[...]/ext_18.12.000/tools/extraction/bin/64bit/etc/context/ADV12.3/qrc.ini"
    but this time because the [...]/ADC12.3/[...] folder doesn't exist in my installation! Instead, a folder "6.1.7" exists in that location. Maybe the function redefinition needs a little more changes?
