  3. Suppress: *WARNING* COMBINE attribute library not defin...
  • Replies 18
  • Subscribers 136
  • Views 27929
Suppress: *WARNING* COMBINE attribute library not defined
Aldo2
Aldo2 over 7 years ago
I use the following commands in my cds.lib file:
DEFINE my_category libs/my_category
ASSIGN my_category DISPLAY my_category_display
ASSIGN my_category COMBINE lib1 lib2 ... libN
as described in https://community.cadence.com/cadence_blogs_8/b/cic/posts/things-you-didn-t-know-about-virtuoso-library-manager.
Library manager appears as I expect, but I get lots of these warnings:
library: 'lib1' file: '.../cds.lib', line: 118
is there a way to suppress them both using ADE and in ocean scripts?
Thank you
Best regards,
Aldo
    Andrew Beckett over 7 years ago in reply to Aldo2
    Aldo,
    Now I'm back at work, I checked in this subversion, and also checked for any reports of issues. I can't find any problem - the only way I can get the warning is if there genuinely is a reference in the COMBINE list to a library that doesn't exist.
    Can you log this with customer support and then give the case number here? I can then pick up the case and maybe we can have a webex and take a look. BTW, I did find an enhancement CCR asking for the warning to be suppressed (CCR 756371), but there are no plans to implement this.
  • Aldo2
    Aldo2 over 7 years ago in reply to Andrew Beckett
    Thank you Andrew.
    I will contact customer support when I'm back to office.
    Best regards,
    Aldo
  • Aldo2
    Aldo2 over 7 years ago in reply to Aldo2
    I found what caused the warnings.
    However the possibility to suppress them would be useful.
    Thank you
    Best regards,
    Aldo
  • ArthurA
    ArthurA over 5 years ago in reply to Aldo2
    Dear Aldo2,
    Do you have a solution for suppressing warnings from dummy libs?
  • Aldo2
    Aldo2 over 5 years ago in reply to ArthurA
    Hello ArthurA,
    I needed to suppress warnings when deleting an item and I used the following command:
    abMuteWarnings(ddDeleteObj(cellId))
    Best Regards
    Aldo
    Andrew Beckett over 5 years ago in reply to Aldo2
    In recent versions, there's a standard function:
    muffleWarnings(ddDeleteObj(cellId))
    which would do something similar. The code that Aldo mentioned is in this post.
  • Aldo2
    Aldo2 over 5 years ago in reply to Andrew Beckett
    Hello Andrew,
    Which is the oldest version of Virtuoso supporting muffleWarnings()?
    Thank you
    Best Regards
    Aldo
    Aldo,
    It was added in IC6.1.8/ICADVM18.1 ISR1 (i.e. .500.1 at the end). Bit unhelpful that it wasn't in a major release (it just missed it). There were some fixes to catch some lower level warnings which were being missed and those were fixed in IC6.1.8/ICADVM18.1 ISR3 (.500.3).
