  3. Noise analyses in Cadence for differential Op-amp
  • Replies 12
  • Views 19461
FormerMember
FormerMember over 7 years ago
Dear friends,
I would like to ask your help if you could guide me to the simulation of the noise for the fully differential op-amp, mainly I am interesting in to finding the Input referred noise (IRN).
Thank you in advance
    Andrew Beckett over 7 years ago +1
    One way would be to have a source across the differential input (provided the common-mode level is set correctly for the differential inputs), or you could use voltage-controlled voltage sources (vcvs…
    Andrew Beckett over 7 years ago in reply to FormerMember +1
    That would work. It doesn't matter what the source setting is (you might set it to be an ac source for an ac analysis, or a sine source for a transient analysis; for the noise analysis it really doesn…
  • Frank Wiedmann
    Frank Wiedmann over 7 years ago in reply to Andrew Beckett +1
    These setups might be simplified by using the ideal_balun component from the analogLib library, which is described in the paper " A Test Bench for Differential Circuits ".
  • FormerMember
    FormerMember over 7 years ago in reply to Andrew Beckett
    Thank you Sir very much for your kind help and kind suggestions
  • FormerMember
    FormerMember over 7 years ago in reply to FormerMember
    Sir I have one issue with the forum that I don't see a notification of the reply from my account, I only know it from my email, how can I see the history of my posts please
