  3. CSF search mechanism - load .cdsinit from $HOME even if...
  • Replies 12
  • Views 12564
CSF search mechanism - load .cdsinit from $HOME even if its disabled in setup.loc
HoWei
HoWei over 7 years ago
I have read the article "Cadence Application Infrastructure User Guide IC6.1.7" to understand the CSF search mechanism. Whilst playing around with the settings, I found that it still loads the ".cdsinit" from $HOME, even if I explicitly did exclude/comment this location in "setup.loc".
In my workarea, the following files are used:
setup.loc:                only "." is enabled as search-location, all others are commented
csfLookupConfig:   only "NONE" is set
For my understanding, the above settings should result in not loading any .cdsinit. But I clearly see that the ~/.cdsinit is loaded (by printing a dedicated message into CIW). I am using ic6.1.7.500.1400.
# cdswhich -lookupconfig .cdsinit
Info (cdswhich): Cadence software is not configured to locate
                 file '.cdsinit' via Cadence Search File mechanism
Question1: Why does virtuoso load the ~/.cdsinit ?
Another thing I did not clearly understand from the above mentioned article, is the requirement for the "csfLookupConfig" file. According to my tests it might be enough to have "cfsLookupConfig" in my workarea to define what file to load via CSF.
Question2: Do I need to have this file in all locations defined in setup.loc, or is it enough to just have it in my workarea (which is the first search location in setup.loc) ?
Rgds.
Holger
    Andrew Beckett over 7 years ago in reply to HoWei +1
    The reason why it's a problem with .cdsinit is because you have an infinite loop - you are loading itself, which loads itself, which loads itself, ad infinitem. The ddGetStartup function only finds the…
  • HoWei
    HoWei over 7 years ago in reply to HoWei
    I found that the following code is doing what I need:
    when(  isFile(".cdsinit_personal") loadi(".cdsinit_personal"))
    when(  isFile("~/.cdsinit") loadi("~/.cdsinit"))
    when(  isFile("~/.cdsinit_personal") loadi("~/.cdsinit_personal"))
    As said - I need to give the locations explicitely.
    Do you see any issue with this ?
    Should be fine - you only need to make sure you don't  end up in a loop - probably wouldn't. I might be tempted to make the first one use "./.cdsinit_personal" (in both the isFile and loadi) to make sure that you don't accidentally load the wrong file if the SKILL path doesn't include "." at the beginning (isFile and load/loadi use the SKILL path - getSkillPath() to resolve local file names).
