  3. Adding dummy elements to the layout
  • Subscribers 130
  • Views 18961
NorNand
NorNand over 6 years ago
I started my layout design and for the matching purpose, I need to add dummy elements like transistors, resistors. whenever I add an instance as a dummy in the layout the LVS will complain that this element doesn't match to the schematic, Then I need to put that instance in the schematic as well, but this procedure makes my design longer.
I believe that there is some tool in Cadence Layout XL that is concerned with adding dummy elements and I hope you could help me with. Or if there is no such tool then at least how to ignore elements in the Layout from LVS
  • mschw
    mschw over 6 years ago
    in the "Cadence Virtuoso Layout Suite XL User Guide" there is a section called "Creating Dummy Instances".
    Maybe you can find there what you want.
    Kind regards
    Matthias
  • NorNand
    NorNand over 6 years ago in reply to mschw
    Thank you mschw,
    still, I face a problem... if someone already worked with it will be more clear
    thanks
    Andrew Beckett over 6 years ago in reply to NorNand
    It does tend to help if you actually explain what your problem is - "I face a problem" doesn't really explain what the issue is!
  • NorNand
    NorNand over 6 years ago in reply to Andrew Beckett
    Hi Andrew
    I read the help from Cadence, they explained about something called Model Generator, I think it is a special tool, but I am working with Layout XL editor.
