  3. using the switch in the analoglib
  • Replies 13
  • Views 72935
Iaf22
Iaf22 over 7 years ago
Hello, i'm trying to use the ideal switch (relay) from cadencelib to create a 50MHz clock signal from a variable DC power supply. I have connected the relay with a vsource with the required frequency and set the switch open to 0v and close to 3.3v and the vsource with a pulse of 20MHz from 0 to 3.3v. Now whenever i simulate it i get the same dc voltage on the input and not the required clock. Does anyone know why this is happening?
    Andrew Beckett over 7 years ago +1
    This is because the output is floating (there's no load resistance). So the output is always connected to the input ramp source, either via a 1ohm or a 1Tohm resistance, and so it just follows the input…
    Andrew Beckett over 7 years ago in reply to Iaf22 +1
    You could use either a pvcvs (either pvcvs2 or pvcvsp with the number of inputs set to 2) to multiply the inputs, and then you'd set the Max Coefficient number to 4, and enter 0 for all of the coefficients…
    Given that there are two inputs, the coefficients work this way: F = c0 + c1 * a1 + c2 * a2 + c3 * a1^2 + c4 * a1 * a2 + c5 * a2^2 Where a1 and a2 are the two input voltages. You can type "spectre…
  • Iaf22
    Iaf22 over 7 years ago in reply to Andrew Beckett
    well that was my setup and i got that on the output. A high gain! however the pulsed signal is 1V and the output is not always going to 0V
    You need to use pvcvs2 or pvcvsp with the Num of controlling voltages set to 2. If you use pvcvs then that only has a single (differential) input, and so what you would be getting then is that the fourth coefficient is the fourth power of the difference of the two signals, which is not what you want!
  • Iaf22
    yes that's my fault i didn't take care of the name it works fine thanks a lot!
